Whoa there, fellas. I had a feeling there was more to the initial request than met the eye.
Matt, and others, I completely agree with that philosophy. I've read a hundred posts on the general forum about blades in Iraq, and 99% of them recommend a folder or small fixed blade. I agree. OK? Lemme put some smilies in here...
I just stepped outside and started second guessing the true purpose of these knives. However, I'd like to point out the requirements in the initial post were quite clear:
The knives, one per maker, should be made for the purpose of carrying into engagement and with the knowledge that the primary knife function and probability of function is to kill the enemy when and if necessary.
The knife I'd design for the above purpose would be very different than the one I'd design for general use. A knife that would be a dedicated offensive weapon, to me would look very different than one designed to handle mundane cutting chores. I took the request at face value, and perhaps I should have questioned it... But then again, all you guys seem to have interpreted it differently than I did, so maybe I'm just slow.
Peter-
I mean no offense by this, I'm merely gonna try to better explain my thought process, as I think you may have misunderstood me judging by your reply.
You said, "in the very rare instance when a soldier has to do something like take out a sentry, the accepted method is from behind and either a throat cut or more often, a choke hold to keep him quiet and occupy his hands and a reverse thrust through the heart. The blade should not be overly long (6" to 8" max). Much longer and it gets unwieldy and with extremely long blades, you run the risk of over penetrating during the struggle (people don't die quickly from a knife wound) and cutting yourself."
Well, I don't want to get on the topic of sentry removal, but why would I want to cut a throat when it would be so much easier to lop his entire head off? Whey would I want to thrust a little slice through him, when I could remove a leg at the thigh, or arm at the shoulder? People don't die quickly after being split open from the shoulder to halfway down their torso? Because
that's the kind of cutting power I'd want at my disposal. I really believe my big Bowie would have no problem with any of these feats, considering what it can do to animals. Though the long blade would be a disadvantage in a grapple situation, again, I'm thinking offensive use. I apologize for being so frank here, I guess I'm just feeling a little defensive.
