- Sep 21, 2014
Really???!!Not much time.
Perhaps I need your definition of 'much'?
Looks like you got plenty there.I wish I had more tang to work with...
That's one of the nice things about WA handles. This is easily hidden.the tang being offset...does "bother me"
Yep that ship has sailedCool WIP. If it's not too late I think a western style handle would aestheticaly work better with this profile, especially because of the wide neck and tip and curves on the blade.
Looking forward to what you come up with.Yep that ship has sailed
Oval with a slight taper from the neck width to slightly larger towards back. Flat or 2" wheel at 15-25Ā° on top of the handle for transition to the blade and making the pinch grip more comfortable.Any advice on how long the handle should be?
I'd let this thread slip by since I last posted - Darn what a good thread!Any advice on how long the handle should be?
Octagonal will look akward if you ask me.
5" total length on the handle - I've never used anything but octagonal for a Wa handle. I find some folks prefer the Wa handle, other folks like the Western style.
Ole RedBeard, you did good on this thread with LOTS of good photos to follow along with.
Thank you for the details sir. I'll give the oval a go. On your oval handles do you only oval the bottom or do you oval the top as well? Could you oval the bottom and 45 chamfer the top?
Thank you sir!
Man those concave recesses look comfortable!
How long is the blade? For wa handles, I typically end up around 130-135mm handle length for knives around 160-175mm blade length, but I prefer skinnier longer handles. Your blade seems to be pretty sturdy with a tall neck, I think the handles Fredy showed would be a good match.Any advice on how long the handle should be?
Although it may not be the most traditional or attractive; that was by design... just playing around. It's not a single curve, rather 3 sections separated by two curvesHow long is the blade? For wa handles, I typically end up around 130-135mm handle length for knives around 160-175mm blade length, but I prefer skinnier longer handles. Your blade seems to be pretty sturdy with a tall neck, I think the handles Fredy showed would be a good match.
Not sure if I am imagining this, but the profile of the spine of your knife does not look smooth to me in the pictures you posted. There appear to be a couple of kinks with a flat section in between. It's really hard to tell from the lo-res pictures and I might well be imagining it, but I see it in every picture where the spine is visible. I tried to highlight the approximate location in the picture below.
