Funny, you say you don't like them, but you don't say WHY you don't like them? Looks? They are knives, they have an edge that cuts. They will probably do most things you need them for. I like them because of the fact that they DO have two edges, because since those two edges are completely straight, they're much easier to sharpen evenly on a simple benchstone, especially if it's a shorter blade. Sharpening an edge that curves towards the tip is harder. Since there are two separate edges you can have two different edge angles on the tip and the main edge, if you want to use the tip more for prying and scraping. You don't even have to sharpen the tip if you don't feel like it, just keep the main edge slicing sharp and the tip for grunt work. I also like that if you happen to break off the tip, it is easier to regrind a new tip, since it's just a straight line.So I like everything about a knife minus the tanto blade. However since I don’t own a tanto bladed knife maybe I should be more open minded. So let’s hear it. Tanto... pro’s and con’s...
The myth that tantos are hard to sharpen is perpetuated by people that think knife sharpening is just swiping on a Sharpmaker for 20 minutes and then wondering why the edge is so dull. They are very simple to sharpen. Two straight edges is actually easier to sharpen than a typical drop point blade with curve that needs to be minded and adapted to.Funny, you say you don't like them, but you don't say WHY you don't like them? Looks? They are knives, they have an edge that cuts. They will probably do most things you need them for. I like them because of the fact that they DO have two edges, because since those two edges are completely straight, they're much easier to sharpen evenly on a simple benchstone, especially if it's a shorter blade. Sharpening an edge that curves towards the tip is harder. Since there are two separate edges you can have two different edge angles on the tip and the main edge, if you want to use the tip more for prying and scraping. You don't even have to sharpen the tip if you don't feel like it, just keep the main edge slicing sharp and the tip for grunt work. I also like that if you happen to break off the tip, it is easier to regrind a new tip, since it's just a straight line.
To sum up, they are simply made blades that are easy to maintain IMO. They are also relatively easy to make. I think a tanto blade will be my next knife project.
For the cons, obviously, you don't have a curved edge portion, which you want sometimes. Also, if you're using something like a Spyderco Sharpmaker for sharpening, the tip edge becomes a bit more tedious to sharpen, since you need to avoid rounding off the separating corner between the edges. A wider flat sharpening surface is the way to go.
That's fair. I just don't think needing to either re-clamp to the correct angle or adjust your grip if free-handing is that much of an inconvenience.Sure tantos are harder to sharpen on a sharpmaker but they are also harder to sharpen on many of the popular guided systems out there now. On a KME, Hapstone, Wicked Edge, etc you are going to have to unclamp and then reclamp the blade in a different location in order to get the edge leading up to the tip. Is it the end of the world? No. However it is more difficult to do than just clamping it once and running the stone along the length of the edge like you would do with a droppoint, wharncliff, clip point, or other common blade types.
If you are an experienced freehand sharpener im sure its not all that much harder than a droppoint in that the edges are straight so there is no need for wrist involvement. But this is dependent on how you do your sharpening and most people here i would guess are using one of those systems.
I say use that guided sharpening system for the main edge of the tanto blade, then don't bother using it for the tip part of the edge. Sharpening that tiny bit of straight edge free hand isn't that hard, even if you're not that experienced.Sure tantos are harder to sharpen on a sharpmaker but they are also harder to sharpen on many of the popular guided systems out there now. On a KME, Hapstone, Wicked Edge, etc you are going to have to unclamp and then reclamp the blade in a different location in order to get the edge leading up to the tip. Is it the end of the world? No. However it is more difficult to do than just clamping it once and running the stone along the length of the edge like you would do with a droppoint, wharncliff, clip point, or other common blade types.
Many pro points - mostly centered on strength.
My biggest con - - any Tanto style knife I ever picked up was/is a chisel grind, with the flat on the right.
Since I'm right handed & hold things I slice with my left hand, that's right hand flat is useless - - worse than useless really since it slices everything all katty-whampass..
I guess a fella could hunt one down with a flat on the left - but - why bother when there are so many other knives out there to spend my money on.
