- Apr 17, 2009
Ok. Great questions and I want to get into these in some detail. However, I am way behind for the Seattle show and want to take some pics etc... Let this suffice for a few more days if you will...
First, let's start with question #3 by Patrice. Checklist:
a) is the ricasso perfectly rectangular and square and parallel in the three directions? (not the side towards the blade.)
b) are the shoulders square and have at least 1/16" flat contact point?
c) is the guard slot bigger on the backside (relief) and just a little smaller than the ricasso thickness on the front?
You guys know all this stuff already, right? I'm sure there are tons of threads on this, but here is my take. The place where I used to have the most problems was with the ricasso itself and not the actual guard. You can't get square shoulders if the faces of the ricasso aren't parallel. So, I need you to check it very closely with calipers and make it perfect. The plunges are based off of the ricasso and the edge itself is based off of the ricasso. If you have a tapered tang, it is based off of the ricasso. So, if you are having guard fit-up trouble, make your ricasso perfect.
Next, I had trouble making the shoulders perfectly perpendicular even with the carbide faced file-guide. Take your time and file/sand from both directions. You always tend to remove more material from the direction the file/belt is moving. Even with the carbide faces, you still want to go at if from both sides. Trust me. There is a really cool way of checking the square when you're done, but I don't know if Tim Hancock wants me to share it. Possibly it has been shared here before... (hint: think of using a common house-hold item in a way to enlarge, visually, any errors you might have trouble seeing. - and it's not a magnifying glass - you should be using that anyway.)
And for the final press-fit, I really like the jig that clamps to the tang and then you can dial up two bolts to squeeze the guard onto the shoulders. Get one of those. I've seen a cool alluminum one here in one of the threads recently. I know Uncle Al's sells one and I bet Nathan makes one too. Be slow and deliberate in every step here. Make each one perfect and your result will be better than mine. I hate fitting guards and only do about one a year. Good luck.
