- Dec 5, 2005
I would love to make you one!I need one for my dagger.![]()
I remember you saying this to me at Blade like 4 or 5 years ago . . . longer? I knew right then you had good taste! I believe you made at least one dagger several years ago which was an even closer version to one of Billy's inlaid integrals which you picture above. I coveted it in a big way.View attachment 1459209
I can see what you're referring to, but no, that might be a coincidence.
However every dagger I make is inspired by Billy Mace Imel. That's not to say there is deliberate borrowing of design elements as much as simply literally inspired.
His are art knives whereas mine are functional, but I always measure myself against him.
Nathan, I have a few of the stones and find them very effective. However, I have only used them in the rectangular shape they came in. Do you mind sharing how you shape the stones to tackle the hollow grinds? Do you just shape them on the grinder?Right? It's maddening the lack of comprehension...
Folks, this isn't like using a rotary tool with a tiny surface area that will lead to trouble nor does it leave a rough finish. It automates the back and forth scrubbing used with die makers stones and saves you time and elbow grease. If you've never used diemakers stones you may not have a good frame of reference. They're commonly used to finish tool marks from molds and a mold maker that I know who is also a knife maker swears by his. That said, the real deal is considerably more expensive so I'm a little skeptical about this unit just because it's so inexpensive. I think it's an interesting idea.
I use N grade die makers stones from Falcon tool here for scrubbing tool marks from my work. It doesn't dull or round over details like paper. The stone doesn't cut as much as the slurry it forms cuts so technique is important. It's a fast and precise way to shape steel without causing undulations like you'd get from a rotary tool.
This mirror finish was done with stones. I didn't have the best milling machines back then and the tool marks were substantial. I stoned them out to 800 grit and went back to either 400 or 600 grit paper through to mirror finish. I don't think I could have done it very well without the stones. These ultrasonic die profilers are what is used in industry rather than just sawing back and forth with a stone. You'd develop an accumulative stress disorder without something like that if you did it every day.
I'm not sure, because I haven't personally tried it, but I would think a tool like that would have application in our field.
15-20 pieces of miscellaneous inventory, Friday Dec 11th. "Hard Thin" Field Knives and a few Behemother choppers
Sales are at 3:00 eastern time.
Out in the main sale area here: https://www.bladeforums.com/forums/for-sale-fixed-blades.754/
Hey Nathan. Sorry if I missed the announcement; when will more daggers be up?
Thanks.
I was wondering the same thing. ThanksNathan, I read the phrase "limited run" in one your most recent Kephart related posts, IIRC. I have been toying with the idea of adding another to my preorder because I always get at least one back up CPK (not named chopper) but my urge for instant gratification forces me toward scoring another one during the upcoming Fridays sales in 2021 as the CPK-Keps get produced and presented.
I am still leaning in this way to get at least one more but the word which you used, i.e, limited, leaves a bit too much to luck during the upcoming FS's. My original interpretation of "limited" was more along the lines of a non-recurring future pattern like one-and-done but if you could perhaps elaborate? If you mean something like 50 or so more on top of whatever the PO numbers end up, I may wish to reconsider my current decision by adding to my preorder to stave off the future needs to scramble. Thank you.
This answer is available at length in this subforum. Not sure where, but Nathan has explained at length.Another: why did you switch from elmax to aebl for a stainless option?
IIRC, the abbreviated version = Elmax has better wear resistance, but AEBL has better toughness, and most of the dulling/edge damage was, as Nathan put it, due to microchipping from clacking the edge on hard things, thus a preference for toughness over pure wear resistance.This answer is available at length in this subforum. Not sure where, but Nathan has explained at length.
After reading you comments about tapered tangs in the kephart thread, I started to wonder. Is there any chance you guys might produce a Loveless style hunter somewhere down the road? If so, Integral?
About the new kephart, will the scales be quilted or smooth?
Thanks!
