000Robert
Platinum Member
- Mar 28, 2020
idunno. 20? It's a lot of work tweaking fixtures for just 20 knives. But so is hand grinding 20 knives the hard way.....
I want a DEF also!
Yeah, I don't think hitting 20 is going to be a problem either.I don’t think getting to 20 is going to be a problem.
Don't forget Mike, Marc, and YOURSELF GusI think with Tom and Mat’s order we should have close to twenty already.
Jo's roast beef with horseradish and tomato, toasted with melted cheeseWhat’s you’re favorite sandwich ?
Which one of your blades do you use to cut the beef?Jo's roast beef with horseradish and tomato, toasted with melted cheese
Dammit, this is gonna be expensive......Don't forget Mike, Marc, and YOURSELF Gus
I don’t see Ebonite as a scale option listed for the upcoming UF2. Is Ebonite out for this run? Thanks in advance.
Are the AEB-L ground the same as Delta 3V? i.e. just steel and HT difference.
Nathan, would you please clarify for me the double edge dagger grind option for the UF2?
View attachment 1572688View attachment 1572687Is it the top photo or the bottom, which was the Double Edge Fighter option on OG UF?
I stole pics from satin grind post, top is Gusbuster and bottom is Tigerden
(Thank you, fellas)
In addition to the standard UF, I will also offer a double edged version of it. The sale will be for a rear bevel ground onto the standard, but if there is much interest I'll do a double edge variation instead.
