Mine usually has my flashlight in it, but if my little knife is second to something larger it might ride in there too.
As a lefty I can't have my main knife over on the right side.
Of course as it starts warming up I don't have a watch Pocket in my shorts.
I think I'm going to look for some denem carpenter type shorts that do have one.
Today it's been just the little 12OT
Oh I've checked my pocket multiple times to make sure I didn't loose it just to discover it didn't even shift around.Wonderful little knife there, Hickory!
I always thought those particular Old Timer's made for a perfect pocket knife. Small enough to forget about until it's needed, but enough to do the job. And the great carbon steel that Scrade used with a nice thin edge cut like the dickens.
Yeah. I do the same thing with my small knives. You hardly feel them in your pocket. This is good, but if you set it down or somehow loose it, it might be a while before you notice. I would hate to loose a Schrade USA knife. Very useful knife!Oh I've checked my pocket multiple times to make sure I didn't loose it just to discover it didn't even shift around.
It definitely cuts really well for sure.
Me too. In fact I have been thinking of Pembertons and it would be pretty fun to make a few caplifter versions...like this for example.
Nice accumulation of smalls. I guess my question is.... Do you use your peanut or do you generally reach for a larger knife?Here are my smalls that fit in my coin (5th) pocket. Have at least one of these every day. One of the peanuts rides along 80% of the time.
I use the Peanuts for about 50-60% of my daily cutting chores and they are great little fidgets also. I’ve even used them to cut steaks at restaurants. Even my bigger secondary knifes aren’t that big, slimline trappers, Mini copperlocks and such. Outdoors I will have some sort of folding Hunter with me.Nice accumulation of smalls. I guess my question is.... Do you use your peanut or do you generally reach for a larger knife?
For me, it is and was an adjustment to accept using a smaller knife as my dominant edc. I like the folding hunters for the woods and later in life I generally used this kind of knife as my hunting knife. Now I have been mostly carrying a fixed blade in the woods accompanied by a folder in my pocket.
Added: When I first added the peanut to the coin pocket, frankly I seldom reached for it. Then later I decided to leave the larger slippie or modern home and see how it went. It went just fine and I have essentially made a semi-permanent adjustment to my edc philosophy. Can't say that I won't change again, but I change very slowly.
When I say I change very slowly, you have to understand that I had carried a 111mm SAK for 15 years pretty much every day. I carried clipped moderns also, but couldn't bring myself to dumping the larger SAK. Cold turkey is about the only way to evaluate if a knife works for you.That's the way I had to do it.
So many years ago, when I first started my downsizing and I started by carrying my dad's old peanut, I was still carrying my Buck stockman in my right hand pocket. I found that by habit I reached for the stockman first. Only after I made the decision to go cold turkey, and carry only the peanut for an experiment, did I really find out how useful the smaller knife was. It got used first only because there was no default knife on standby. It was really really weird for a bit, then I got used to it.
The only fault it had was food service, and since most restaurants have tableware, it wasn't really a problem, and I don't carry jars of peanut butter out in the woods.
