Is that different than running in reverse normally?any suggestions on how to get my belts from jumping off the Brodbeck disc attachment while running in reverse?
I've haven't run my machine in reverse since I installed the switch, I added the switch specifically for the disc sanding attachmentIs that different than running in reverse normally?
I run reverse on my 2x72 for convex/slack belt grinding on the top side.
idk if you do that too?
that switchI don't understand?
What do you mean adding the switch?
My switch on my vfd is what changes the direction of the motor/belt
Hmmm...any suggestions on how to get my belts from jumping off the Brodbeck disc attachment while running in reverse?
that's solid adviceHmmm...
Got my attachment a couple weeks ago and love it. I do not have that issue running it on reverse. Runs as it should.
Send Ben Secrist (Broadbeck) an email in regards to this. He was helpful to me when I dealt with him regarding trimpots adjustments.
Yes I did, as per the instructions. Ben tells me it will not affect the 2X72 grinder operation.that's solid advice
did you end up tuning the vfd?
I have the same grinder...and switch. I have to adjust tracking (of course) when I run in reverse on a flat platen....but never had a belt jumping off.that switch
