Do you mean the On-Off foot switch? I use a couple of them in the shop for turning fixed speed tools like a drill press or lathe on and off while my hands are busy. They are a very good item for the money. I prefer the one that is Step-On step-OFF. The dead-man type (Keep pressed for ON) is good for hand tools like a die grinder or larger size power carver that you use sitting down.
Besides the VFD tools like belt and disc grinders, I am changing the motors on many other shop tools to VFD and wanted to make a variable speed foot pedal I could move from tool to tool. It is usually simple to change a drill press, lathe, band saw, etc. to 3-phase and run off a VFD. With a VS foot control, I can use one VFD to run several nearby tools.
The HF pedals say they are good for 15 amps, but like most of their tools that is a little optimistic. I would not suggest running more than 10 amps through one for any length of time.
For higher HP motors on fixed speed tools, I made a foot switch control box that uses 12V through the foot switch to control an SSR that turns the high amperage current on and off. I use two 40-amp SSRs and a heat sink. It has sockets for 120VAC and 240VAC tools. Just plug the HF foot switch into the control box and it will control anything that the SSRs can take. Only a few milliamps of 12VDC control voltage goes through the foot switch.
