Looks good. I may borrow part of that design. Here's a few photos of what I've done to date on mine. I need to order a couple fans. I also painted the inside of the box with Flame resistant paint. Basically header paint. To prevent the spread of any possible fires when I use the laser on wood. I need to order more and put on a second coat. The plywood sucked it right up. In insight an undercoat of primer paint would have been better. Then the header paint as the topcoat.Started my laser box today. Now waiting for ordered parts to arrive to complete it.
Not my design, found plans online and modified to meet my needs.
I don't know how much of a problem it really is. I've never seen any actual damage from a fire started by one of these desk top lasers. But it's mentioned fairly frequently that it's a possibility. So I thought I'd go ahead and do it.Oh man, I never considered the fire retardant paint, will need to order some, and thanks for that heads up.
I'm not sure what the depth of field the 10 watt OLM3 will engrave - at least 1/8" if not a tad more.There are a number of YouTube videos detailing pistol etching/engravings.
I bought the attachment with my laser to etch/engrave cylindrical objects (thermos, cups, etc), but have not ventured into that use just yet.
Thanks, Dan.There are a number of YouTube videos detailing pistol etching/engravings.
Bill, I think what you need for that application is more about depth of field, rather than the source technology of the laser beam. The depth of field will depend on the properties of the lens and that will be different from product to product. If I remember correctly when I researched the depth of field for the laser I have, it was supposed to be about 1-2 mm, give or take, so somewhat in line with what you say. But then again the diode laser is much worse at engraving steel than fiber laser (you need a powerful one to make a deep mark), so that may diminish the effect of having nominally larger depth of field. The 1911 slide that I have has about 3 mm of height, so if you wanted to engrave from side to side it would probably not fit in there fully either (but again, I think it will depend on the specific product).Thanks, Dan.
But the cylindrical attachment keeps the engraved surface at exactly the same distance (focal point) by turning cylindrical items. I don't think it will work for just curved surfaces.
That's why I'm asking. Could you, for example, sit a pistol slide, level, with the rounded top exposed, and engrave the curved surface successfully? I know it can be done, but the engraver I spoke with yesterday said his fiber laser needed surfaces level to about 1 mm. to engrave them.
