So you're using Glaser? I've seen Ezcad2, Seacad, BSLapp and Glaser. They all look like the same or similar core program. Mine has BSLapp. No real documentation that I can find. Relying on videos from YT to garner information on program.100%
I'm not ready to start paying for Lightburn, so I'm trying to make the stuff that came with my laser work for me. The challenge is real.
is there a reason you are not running Lightburn? I understand it costs money compared to free EZCAD but if your driver is supported by Lightburn it seems to be where everyone gravitates toward. though for ezcad3, lightburn does not have a compatible version out yet.Hoping someone here can help me. I have a 50W fiber. Use EZcad2. Generally have my makers mark and all other stuff dialed, but for the life of me can’t figure out the below:
How do I make my mark and then run a “cleaning pass” all in the same run? I’ve tried messing with multiple PENs, etc but I can’t figure it out. It seems simple and I see the laser guys all running several different setting in the same etch, but it’s my blind spot. Thanks in advance for any help!
Thank you! I guess it’s mainly because I’ve navigated “mostly” learning ezcad and I’m hesitant to restart the learning curve. My time is pretty restricted so I try to be calculated with it. Is the learning curve pretty shallow on lightburn?is there a reason you are not running Lightburn? I understand it costs money compared to free EZCAD but if your driver is supported by Lightburn it seems to be where everyone gravitates toward. though for ezcad3, lightburn does not have a compatible version out yet.
There are some older videos from Fiber Laser Training on you tube where he does show how to do things with EZCAD2. I think he shows how to do a clean pass in the same run.
Hello all! We launched this channel on 6-1-2022 Subscribe now and be the first to be involved. My name is Jeff and I am here to help give you a better understanding of the fiber laser and it’s user software “Ezcad”. We will discuss all sorts of topics and hopefully be able to hone our skill...www.youtube.com
all CAD /Drawing programs have steep learning curves, in my opinion. The general consensus in the laser world though is that Lightburn is significantly more intuitive than Ezcad. I was advised several times to just start with lightburn and skip EZCAD all together. There was an extra step to install the lightburn driver, as my machine, like most fiber laser, is native for Ezcad. But it was straightforward so have been using lightburn from day 1. So can't even give a proper comparison.Thank you! I guess it’s mainly because I’ve navigated “mostly” learning ezcad and I’m hesitant to restart the learning curve. My time is pretty restricted so I try to be calculated with it. Is the learning curve pretty shallow on lightburn?
There is a facebook group called Hybrid Engraving run by Tyler Poor. He is well known in knifemaking circles for hand engraving. He is a leader in hybrid engraving which combines laser techniques with traditional hand techniques.I was going to make an individual post for this but then I saw this megathread and thought I'd pose the question here: has anyone done any wire/general soft metal inlay using a laser to do the initial engraving? Is there a reason this wouldn't work? I'm running a Laserpecker LP4 (just got it) which I believe uses a 2W infrared laser to do its engraving on steel.
Congrats on yours as well!Congrats on the laser - I got a Gweike G2 Pro 30 watt Fiber laser last week and still learning about it. I purchased the LightBurn license for my OLM3 diode laser which was $100, but the Fiber is $200 (I think). For everything we use the laser mostly (knife blades, etc) 30 watt is plenty is my way of thinking. I've got a 150mm work area. I've also got the chuck rotary tool ordered and should be here tomorrow - maybe. Did you get the roller or chuck rotary? Can't see if the cup as a handle on other side or not. That's why I wanted the chuck rotary, those handles tend to get in the way on a roller.
Boy, they sure do mark good on knife blades. Have you marked on brass yet? If so, what settings did you use?
Ken H>
