Wanted to see what I could do with a couple of kitchen knives with broken tips. Have had these kitchen knives for many years and they were dull, a little bent and the tips were broken. My wife is a little hard on knives.
Ran through belts 130, 220, 800, 1000 and then the leather strop belt. Just curved up at the end to create a new tip which worked. The new tip is rounded but sharp to the very end. I used a tub of water to dip the blade into between every pass on the 130 and 220 belt and every couple of passes on the 800 and 1000 belts. The blade felt cool the whole process. I ran the AMK-75 at a slower speed and made a fast pass each time over the belt
The two kitchen knives were sharpened at 15 degrees each side and are extremely sharp. Really sharp.
I also ran a used scrapyard 411 over the sharpener , using the water dunk between passes. The 411 came out very sharp as well and the tip easily cut 6oz leather.
I have enjoyed using the AMK-75 and my knives are sharper than they have ever been.
My only concern would be heat build up as Nathan mentioned. Need to confirm if the water dunk is sufficient to control heat build up.
BROKEN TIP KITCHEN KNIFE CLAMPED UP AND READY TO GO
DUNKED IN WATER BETWEEN PASSES TO CONTROL HEAT BUILD UP
BROKEN TIP ON TOP VERSUS REPROFILED TIP ON BOTTOM
KITCHEN KNIVES HAIR POPPING SHARP
SCRAPYARD 411 VERY SHARP
SCRAPYARD 411 TIP CUTTING THROUGH 6oz LEATHER WITH EASE
