- Mar 29, 2007
I've got two main thoughts, one is similar to the two finger whancliffe I did a while back:
That's 4.75 inches OAL, snug and safe 2 finger bird's head grip
The other idea is a tapered handle similar to the pattern 2 necker, but with a slightlyu dropped edge seax blade.
For the big ones, I'm thinkin. If it's going to be a chopper, I'd honestly rather go flat sided 1/8 inch and 9 inches or so. It would be a seax, look seax like, and do a lot of similar chopping to the flat edge profilee southeast asian choppers- but a *touch* heavier in the blade. OTOH, if ti's going to be a.. potential anti-zombie device (or other undesirables) as well, go with a slightly less broad design, shoot up to a nominal 3/16 spine with some distal taper, and convex.
For the medium size, well. Your wharncliffe project is generating a lot of thought in me for how I'd do the modern seax style in a 3 inch instead of a 5.5 to 6 inch blade. The only real issue is that a wharnie by definition has ZERO belly, and I like the very slight belly on the modern seax blades. the slow curving spine is really nice, and I think it works better with the teensy bit of belly at the tip.
