You need to look at:
What you can shoot well
What is reliable
What you can conceal well
What you can draw from concealment
if you can’t hit what you’re aiming at, doesn’t matter what you have, so practice all of the above with dry firing and reloading to create muscle memory.
THISTHISTHISTHIS
You must carry what you are comfortable with. I grew up shooting all kinds of pistols and was a gunsmith for years. I can pick up a DA revolver, a hi power, a glock, a beretta m9 and feel at home with any. But not everyone has had that opportunity. You have to choose what you can use without thinking under duress.
Are you quite accustomed to firearms? If not, I recommend a double action only small revolver. You pull it out, point and start squeezing until it goes click, then throw the empty gun at them. It’s easy, it’s thoughtless with some practice. Are you quite comfortable with automatics? I carry an M&P Shield custom shop 9mm with Speer gold dot +P 124g. It’s fairly East under duress, it’s recoil isn’t too bad with the mag porting, and it’s small and easily concealable. I carry it in one of @Horsewright pancake sheath and it disappears under a t shirt.
After that, as quoted, practice practice practice. Practicing the draw is more important than the actual firing. Draw it, reholster it. Over and over and over. Until you can do it without a thought. Then keep practicing. When things go bad, that’s when you’ll be nervous and it’ll get hung up in your shirt. Then, practice firing. Not just the standard stances either. Practice firing while backing up, getting away from a threat (do this dry firing for awhile first!). Until you can do this without thinking.
Now, I practice about once a month (although it’s slacked off the last couple years). I try to do about 100-300 rounds a month with the weapon I carry. I really need to get back into that habit.
Hope this helps!
...talking about knives; and, for days chatting about guns....Most of us gun nuts could go on and on for hours.
n2s
nice picsFor sure get your CCW.
I rotate between Glock 22c (.40 cal)
S&W .40 Shield
And .357 Ruger Sp101
The biggest advice is to try and shoot what you plan on buying. Many firearms will fit and work. Some will never feel right or work for you.
Notice the carry-wear on that rig. It is truly an EDC in pants that have a large enough pocket opening. If you haven't thought about your pants, you haven't thought enough about carrying a firearm. It's ride friendly too.Not being a chore to carry has my attention.
You need mega. Firehose pants, that's mega - and Firehose Flex is ligher for summer - and they have nice shorts that are tough.I will say correct pants has always been a big thing for me. Toughness is a necessity her at the Swamp Rat headquarters if you haven't noticed.
What is reliable
I will carry anything from an LCP on summer days to full size H&K when weather and jackets allow.
