BenjaminRush
- Mar 17, 2015
Its much thinner..With ironwood you could modify it yourself..I didnt even want to try wth carbon fiber..Really did like the way the scandi grind cut thoughI've often wondered how the contoured handles compare to the flatter carbon fiber (and ironwood, which is the same shape). I would get some hot spots, so I removed the clip from mine. It helps, but the handle is still a little flatter than I'd like it to be for hard use or extended use.
Wow that is thin. I’ve tried to get rid of the micro bevel and create a convex on mine, but I’ve only got a water stone so it’s more “unique” than exactIts much thinner..With ironwood you could modify it yourself..I didnt even want to try wth carbon fiber..Really did like the way the scandi grind cut though
Only thing with the contoured scales is the thumb lugs stick out a mile on each side so ya just end up with a precise little bruise instead of a big one...HA!!Wow that is thin. I’ve tried to get rid of the micro bevel and create a convex on mine, but I’ve only got a water stone so it’s more “unique” than exact
Modern folders for ya!Only thing with the contoured scales is the thumb lugs stick out a mile on each side so ya just end up with a precise little bruise instead of a big one...HA!!
They might help a little but the problem is my right hand, I was initially paralyzed from the neck down and oddly my right hand came back kind of weak and only some of the muscles are strong-ish (i hope that make sense) my left hand is almost completely functional, so the problem just comes when my right hand is wet or its cold, or I am holding something that wont sit in my lap (im in a wheelchair) because I cant move my arms very good to stick it in my armpit or something haha The traditional thats easiest for me to open is a case sodbuster even though it has a stiffer spring and not pinchable because they are so fat and easy to hold on to.
