- May 26, 2000
I make this mistake, still, once in a while. I've tried to learn that when I notice myself slaving away down in the minutiae, to pull my head back up to the "10,000 foot level" and look at the big picture. Troubleshooting in particular, especially where you have a lot of existing experience finding difficult problems that do require you to think through the minutiae, can cause one to miss obvious and simple things because your focus was too "close" ... not at a high enough level.Originally posted by Graymaker
I spent a long time in auto mechanics along with many other things
and it was very easy to over analyze and miss the basic things and if you did the rest did not help a hole lot.
Like being able to argue either side of any particular debate (i.e. putting your early preference for a given side TO the side to analyze the other viewpoint), being able to view problems from various angles and from various altitudes it's a mental model that seems to pay off.
Ed has commented repeatedly on the benefits he has seen from buying a big inventory of stock from the same mill run. It eliminates one pretty big variable from the equation.Originally posted by Graymaker
For one I may get some O1 at .85 or as much 1.0 or more carbon,
which one is better for a blade you and I both know which one
but we don't know what we are getting when the factors change with a + or - limit like that and that is just carbon,
and we get what we get and we (at least I) can't even be sure of what we have most the time other
than sending the stuff out to be tested all the time.
What I'm wondering is if any of the steel sources will send you guys a materials certification sheet, a batch or mill-run steel analysis sheet. We demand this kind of paperwork all the time in industry. Of course we also double check it with a Positive Material Identification (PMI) device (being professionally skeptical and having huge safety and business risk if we don't), which typically is done by an x-ray fluorescence machine that can pretty much nail the alloy composition EXCEPT for the carbon content, for which there is a spark tester that does leave a mark on the material (a small one) while gauging the emission spectrum of the spark in estimating carbon content. Those PMI devices are pricey though, $20k on up I believe.
I guess you can probably get a cert sheet if you buy enough volume, or buy straight from the factory, but buying a mill run, depending on the material and the mill, is of course a pretty big investment for one alloy (to state the obvious).
Maybe if enough of you started demanding a photocopy of the mill run certification of analysis, the steel dealers would start obtaining such paperwork on your behalf and passing it along.
Until then, it strikes me as important to have as much testing equipment as you can in your shop, so that if you do get some steel that has more carbon or less carbon, you stand a chance of figuring it out pretty quickly based on the results that flow from your perhaps "typical" heat treat protocol for the stuff after your first blade from that batch of alloy.
Surfing EBay for a used but decent condition Rockwell tester (and some calibration blocks) is just one example of a tool that, if I were a maker (and I might be one day, seriously), I'd sure invest in when I could. Maybe some kind of used or inexpensive microscope. And a temperature controlled oven. And ... and...
Being able to quickly adjust your heat treat based on the alloy analysis and certain other in-shop test results seems like it should be a tractable path.
