- Mar 7, 2001
Jazzz,
One needs paid membership to do PM ...
.Chris "Anagarika";16360288 said:Jazzz,
[/URL][/IMG]
In my opinion its an awesome knife but the blade looks a little small in that handles when closed.
What does that cost?
Chris "Anagarika";16360396 said:
What a dummy I am. I quoted myself. I meant thanks, bro to you.
Chris "Anagarika";16362991 said:Glad to help
Some questions:
I always feel Delica blade is short compared to Stretch. Any possible way to make it longer while keeping the same handle length? Since it's straight, perhaps there's enough handle length? Add a bit of kick to elevate the tip?
From your video, what is the cut that definitely need a wharnie and which can be done with normal Delica but easier with wharnie? And the reason?
Don't mean to challenge the usefulness, but my use is so light it's not easy to understand.
Jazz said:Thanks for the discussion, Sal. First, if anyone pays attention to Mr. Janich's explanations on straight edges in slicing, they'll know about how they cut to the tip and don't slide off. Another reason I want a wharnie for work is this: when inserting the tip in tape or whatever, with the straight edge the tip is already there - with a belly, you have to lift your hand a fair amount to get the tip inserted. Here are 2 pics to show what I mean. The edge of the desk is the "box or tape, etc."...
The belly is fine for my EDC, but at work where I do a lot of this, it gets annoying. I've just found the wharnie works - period. As long as the point isn't too pointy, it's plenty strong with the right blade thickness and grind.
I explain it here, kind of (Spyderco forum). Any blade will work, of course. The wharnie just has less possible slippage. Less, not perfect. For work, I much prefer it after years of cutting at work.
I'm sure it could be made longer, but why? Any longer gets unwieldy - in the way in close quarters and cramped spaces.
I'd say it's not a matter of which is better. They are just different, and probably excel at different tasks. To me, more options is always better.
Chris "Anagarika";16364680 said:Hi Jazzz,
Again, please bear with me. Your years of cutting at work is what intrigues me and you definitely have more mileage and that contributed to the preference..
Yes, I remember the tip placement. That's undisputed fact that wharnie is better.
What I asked is about your video where some of the cutting is not 'insert tip and pull', but more of a push cut into the material using the edge, somewhere along the length. There must be a difference and perhaps you can help articulating it to educate light user like me. Perhaps if you don't mind going back and do some of it using normal Delica and noticing the difference? For example, cutting the round tube and slicing apple. The two are what I remember where I thought the difference is not significant. I might be wrong, and want to learn. Since testing usually takes time, I don't want to rush you.
Now, to the question of why max out the blade length? It's exactly for making it usable longer. For a wharnie, the sharpening has to be whole length of the blade to preserve the straight edge. So the whole length will move up and get shorter. Maxing out the blade into the handle will probably give a longer service time for the user. I'm guessing 1-2mm is possible.
