- Mar 8, 2008
That is not the same edge angle. That should be abundantly obvious.
If the starting and stopping points of the arc are at the intersection of the straights, you have more metal behind the edge on the convex grind. Period. Every time.
Ok, let's say the convex edge had a 1 mile radius. It would look identical to the V edge (distance and angle), but would have a tiny bulge making it convex. In this case, it would still have more metal behind the edge (albeit, not much)
Radius is everything when it comes to a convex edge.Radius is irrelevant. Again, read tangent.
Now, if the starting point of the arc is higher than the intersection of the V and the arc has a large radius, the V grind will have more metal behind it. In other words, both types of drawings in this thread are correct and everyone is right!
Again, even though it's already been shown multiple times in multiple ways with common math, if you want to get an approximation of your edge angle on a convex, take it to a piece of hard plastic, wood, or other firm and non/minimally-deforming target surface and see the lowest angle it'll bite at. That's pretty darn close (though slightly in excess of) your edge angle. Super simple to test for, though it's an approximation.
