Untitled by GaryWGraley, on Flickr
Untitled by GaryWGraley, on FlickrYou are correct about the white side of your stone, that is for polishing for a mirror finish, they don't cut at all, but the pink side does. I use oil on my pink stone, i personally find it seems to cut a bit better, but that might be my imagination. But i do think they clean up better after use, i just wipe it down with a rag, the one i have does not absorb the oil and just wipes clean. But it may clog up over time.Touched up my Opinel #8 using this small 4" by 1" stone, CBRIGHT 1PC Dual Sided 3000-4000#/8000-10000# Fine Grinding and Polishing Ruby stone and Agate Stone. While the pink side does some cutting, I have never found the white side, which is suppose to be up to 10k to make any difference in sharpening at all, so, I mainly use the pink side which does provide a nice sharp edge.
the water on there just shows it isn't soaking into it, when I sharpen I don't use any water on the stone, but I do need to scrub it clean using Bar Keepers Friend to clean the particles out...
G2
Can i ask where you got those from.my Nano Hone diamond sharpening stones.
I buy all my stones from trusty good old Gritomatic. Best place for anything to do with sharpening.Can i ask where you got those from.
Thanks very much.I buy all my stones from trusty good old Gritomatic. Best place for anything to do with sharpening.
Nano Hone Diamond Resin Plate [6" x 1"]
Nano Hone Diamond Resin Plate for Edge Pro is used for sharpening knives on Hapstone, TSProf, and all Edge Pro compatible guided knife sharpeners. Diamond stones offer excellent performance in sharpening knives of any steel.The honeycomb matrix is an original design by Hap Stanley. The resin is...www.gritomatic.com
Do you mind if I ask how these stones compare to the various Venevs?I buy all my stones from trusty good old Gritomatic. Best place for anything to do with sharpening.
Honestly, it's too early for me to give a proper opinion of the Nano Hones as I've only done 2 knives with them so far.Do you mind if I ask how these stones compare to the various Venevs?
Great looking set up. A designated sharpening space with good lighting makes all the difference.Just for you,cudgee , a few pics of the Kadet Pro in action, this evening.
The last photo shows my lighting setup, for my sharpening station.
FYI, I recently designed an attachment for the Kadet Pro and Kadet with and articulating arm for a light system. It attaches directly to the Kadet. Gritomatic is testing it out and should release it as an accessory/upgrade in the near future.
