- Aug 11, 2021
Nice! I also use gunny juice 1m and .25mAnd today.. another 3 santokus.
Then ordered a 5000 grit Chosera stone and some 1m Gunny juice and balsa strop.
It seems to work best on "super steels"
I can see how the edge termination goes right into the plunge. Hate that. How are you avoiding widening? Adjusting the sharpening angle for different sections of the blade?New to me 940. This blade is thicker in spots, like the curve near the tip, and right at the heal. Really having to work to get the angle totally flat.
Sadly no. I should have found a different clamp angle and moved it so that wouldn't happen. The first pic is my 945 (mini s30v) the second is my 940, with s90v. I might rasp that plunge to smooth it out and lightly blast it back to a stone wash or ignore it as the 940 is the workhorse EDC when my 535-3 isn't pocketed. I can't claim to be doing much of this right as this is only the 6th knife I've worked on. (I didn't do my 945 it was done on a Wicked Edge)I can see how the edge termination goes right into the plunge. Hate that. How are you avoiding widening? Adjusting the sharpening angle for different sections of the blade?
Occurs to me that it would be a nice feature in a "fixed" angle system to have some kind of lever that allowed you to manually raise the sharpening angle 0-2° for situations like this. Kind of an adjuster *under* a micro-adjuster?
Nice job. Can i ask you if you found the 80 grit not too low a grit, or did you have to reprofile from a more obtuse angle. Whatever, like your work and the sharpener doesn't look too shabby either.Picked up this lightly used Cutlery Shoppe Exclusive S90V Manix 2 LW, for a co-worker, and put a nice semi-polished edge on it for him, earlier this evening.
Sharpened on the TSProf Kadet Pro at 17 degrees per side, using 80, 250, 650, and 1100 grit Edge Pro Diamond Matrix stones.
Finished on a leather strop with 1 micron diamond emulsion spray. Nice and sharp now.
I like the LW version of the Manix 2, after handling this one, but I'll be waiting until the new "screw together construction" models become available,
before buying one for myself.
ThanksNice job. Can i ask you if you found the 80 grit not too low a grit, or did you have to reprofile from a more obtuse angle. Whatever, like your work and the sharpener doesn't look too shabby either.
Yes mate, you have to be so careful using low grit diamond stones they can get away from you and i speak from experience. I also have some venev stones, i really like them. Love the look of your set up, the Kadet Pro looks like a really good well made system, glad you like it. Have a good week.Thankscudgee The 80 grit worked great, as I did reprofile it, just a bit. I hadn't used the EP Diamond Matrix stones in some time,
and had forgotten just how fast the 80 grit stone cuts. I've been using the Venev Ursa Series stones, but decided to give them a rest on this one.
Still very happy with the ease of use and set-up of the Kadet Pro.![]()
