- Sep 30, 2018
Hi Guys,
I collect Spydercos and have a special love for PM2’s and GB1’s and 2’s. I have quite a few of these. Let’s take PM2’s for example - I’ve often seen the terms “Rock solid” and “fall shut” or “drop shut action” used to describe PM2’s but I’ve started to question what this actually means...
I must own over 20 PM2’s and grabbing the handle and moving the blade vertically while it is locked open have never seen vertical blade play which kind of makes sense to me due to the design of the sloped recess for the lock bar meaning the blade will always be stuck between the stop pin and the lock bar.
However the horizontal blade play is simply a function of how tight the pivot screws are...if it’s very loose then there is a lot of horizontal play. Try taking a screw out completely. If they are very tight then there is no horizontal blade play but the “action” may suffer. So if it’s one I’ve taken apart (a user) I tend to compromise by loosening the pivot screws just enough that the blade will just about start to drop with its own weight. It’s definitely not as “rock solid” (horizontally) when I adjust in that way compared to if I just tighten the pivot screws completely...so It seems like a bit of an oxymoron to me to be rock solid and drop shut or am I just rocking the blade sideways too hard in my tests lol?
