- Nov 19, 2008
The ergonomics are GREAT.
The wave is okay.
The fit and finish is less than great...might be okay depending on what you like.
The steel works fine.
I actually like the pivot Emerson uses.
The chisel grind and/or chisel edge is not as wondrous for my uses, but still cuts stuff.
Pretty much my opinion on them as well.
In general there will be some things people would consider "off" with the fit, for instance the jimping on the handle scales not lining up exactly with the jimping on the liners, not much but a hair off. Or you will see some machining marks on the edges of the liners, for some thats huge, for others it doesn't matter.
For my use the chisel edge is just as good as a v ground edge, I honestly don't see any negatives in use and it seems to take a beating better.
If an owner wanted to they could clean up all of the small issues that some people have, a weak detent is easily fixed by tweaking the second detent in the non locking liner, machine marks can be sanded out, the bevel can be made into a v grind by taking a course stone to it, and the black finish can be all around avoided by ordering a stonewashed one. Fit and finish can be fixed, but you can't fix a lesser designed knife, which is in my opinion where Emersons shine. I've never had another folder that matches my A100 is sturdiness, even with its liner lock which has settled in at 80% engagement (and I'm completely confident in its protecting my fingers).
EKIs are a tool knife, not a jewelry knife.
If you can handle an Emerson before you buy it, its pretty much a sure thing you'll find out immediately if you love them or hate them.
