- Dec 18, 2007
Re: Wicked Edge vs Apex
http://www.wickededgeusa.com/
I could not find much info one the Wicked Edge sharpener so I purchased one...it just made too much sense to me. I spent most of the day with this sharpener and here is my initial review. Of course my opinion is worth what it costs.
First, let me say that I have the required standard issue knife-nut equipment...I own a deluxe Apex and the Sharpmaker (for touch-ups). I have had good results with the Apex and Ben Dale is really a great guy. But I must say the Wicked Edge system is sound and based on a much better concept than the Apex. Sharpening both sides of a stationary blade at the same time blows the Apex away. I don't care who you are, sharpening an expensive knife on an Apex is a very stressful experience.
When you take the Wicked Edge out of the box, you see that this is a precision made tool, excellent materials with very close tolerances. 10 minutes to set it up, max. The blade is locked into a fixed position with the Wicked Edge vice, nothing moves, no switching sides or moving the blade for any reason. WE also includes an Alignment Tool that allows you to place all of your knives in the exact same location each time you sharpen them. You just need to create a list of your knives and record the benchmark where you initially sharpened each blade. Simultaneously sharpening both sides of a blade removes equal amounts of steel keeping both bevels even and the edge centered. This removes only the minimum amount of steel needed to get a sharp edge. After using the Apex for so long, getting the feel of the sharpening motions with the WE was easy. Two handed sharpening is much easier than you would think and I got the hang of it pretty quickly. I really like the custom made two-sided Diamond Blocks that will never need flattening like the Apex water stones. If you expect good results with the Apex, you have the chore of flattening the stones between every knife (this is true of any soft sharpening stones). WE Diamond Blocks cut dry, no slurry. After inspecting the edges I achieved with the WE under a microscope, I see good clean and consistent bevels, from point to belly to rear edge. As with the Apex you have to spend a little more grinding time on the rear edge of the blade to get an even edge bevel. WE is currently out of stock on their Extra & Ultra Fine blocks but these stones will complete the system for me when they arrive.
The bottom line is the Wicked Edge and Edge Pro Apex (Kit 3) both cost about $200. Having purchased and used both systems, all in all I feel Wicked Edge has the best sharpening system available and with the finer polishing stones, the ultimate sharpener foolproof, fast and consistent results.
Anyone want to buy my Apex?
- wd
- wd
