- Oct 18, 2001
*****CONTEST IS NOW OVER******
WINNER ANNOUNCED HERE:
http://www.bladeforums.com/forums/showpost.php?p=8903717&postcount=91
Thanks to all that entered !!!!!
:thumbup:
Just let me know what you think this knife would be good for - based on your personal experience with knives.
Post as many times as you want, as often as you like. I'll put all names in a hat tomorrow at Noon CST and draw one out as a winner.
Thanks! :thumbup:
As a prototype, it has been carried for several months, used in the shop, and sharpened a few times. It definitely shows signs of wear, but no abuse. And, of course, is fully covered by warranty.
Here are the specs:
Overall length = 7.75"
Blade length = 3"
Handle length = 4.75" (yes, a FULL sized handle!)
Steel is 1095, 3/32" thick. Hardened to ~59 HRc.
Handle materials are Burgundy Canvas Micarta over Yellow Liners, held to the blade with aluminum lanyards and 2-ton Devcon Epoxy. Handle fronts
are tapered to make sheathing easier. The micarta has been heavily bead-blasted for a deeply textured grip - even when wet.
The grind is a Scandinavian Zero-Edge grind set at 12 degrees.
There are thumbgrooves on the spine - which has been deburred for comfort (same with the small guard).
The sheath is a Kydex Drop-Loop sheath. All the retention strength of kydex and the carry comfort of a pouch sheath. The eyelets are set up for large TekLoks if you would like to carry it that was as well (can be carried crossdraw canted too!). There is a small drain hole on the backside for blowing out dust/dirt/etc. The loop can accomodate up a 2" wide, double-layer leather belt.
Here is an "In-Hand" pic:
Thanks!
Dan
:thumbup:
Thanks! :thumbup:
Here are the specs:
Blade length = 3"
Thanks!
Dan
