- Jun 2, 2011
can u get a mirror edge with some finer grit micro mesh belts?? like the 1200?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
You could be right. I just don't really know for sure. Maybe Kyel or some one will try it and report back, and let us know if there is any wear. Probably the best thing would be if someone offered a cloth or leather belt in this size but as for now I don't think anything is available. It does seem that loading one of the worn high grit belts with compound does work so maybe that is the best answer to polish edges for now. The one thing that really did take me a long time to realize was how much grit size does make a difference with powered belts compared to hand sharpening. With ajusting pressure wile hand honing I can get a finer,The Worksharp does have 2 plastic wheels yes, but those are high friction and will rotate rather than be abraded. The top wheel however is made of metal. The wheel will turn when making contact with the softer cloth backing, but on the abrasive itself I suspect the abrasive will simply slide over it because of how much harder it is and wear down the wheel. You can ask Kyle from Worksharp, but I suspect his answer will be the same. It's like what happens to a tire if you drive without the rubber.
if anyone who feels they are not getting a consistent edge with the WSKTS - then it may well be worthwhile using something like a SharpMaker or V-hone fine crock sticks to set the actual final edge - as most of the benefits of the convex edge is the actual transition angle/convex profile (but the actual final edge does still have to be consistent to be really sharp) - so V-hones will do that, as a very light finishing touch
anyone come up with a leather belt for this yet or am I asking a dumb question?
I doubt it would be offered. And if it was, the price would probably be high enough that it would simply be easier to use a worn out 6000 belt, or wear out a new one. Is there any particular reason why this method isn't appealing or practical?See my post a couple above. I've sent an inquiry to SurgiSharp.
Andrew
Andrew
That wasn't my point really. I'm just asking, what would be the difference between a leather belt and the 6000 belt in which the grit is forcibly stripped off, leaving nothing but the cloth?Its just hard to beat a loaded leather belt for that last little edge refinement. Its probably just personal preference, but if there wasnt a difference between a leather stropped edge and an extremely high grit polished edge, then why does anyone strop at all?
the engineer who designed the WSKTS
He will use the open ("outdoor") guides, but much like Vincent does---as a visual guide but without really touching the blade to it---"levitating" the knife through it.
As to the guides, another important thing he pointed out is that placing the knife all the way down into the guide (i.e., deeply) changes the sharpening angle quite a bit---to a more obtuse angle. To maintain a shallower angle, the blade needs to ride higher, pressing into the belt less.
I think I have just been made totally redundant in sharpening -
and that's a good thing - for me.
Impressed - isn't really enough of praise for this thing....
Maybe it is my technique, but the WS seems to grind the tips off my practice knives. Is there a way to prevent this?
