Definitely get the in between belts, they will help with mirror polishing - a good leather strop will improve the polish that much more.
I can tell you guys one thing, after a good 4 days of sharpening any knife i can get my hands on, i've realized that i was holding the edge at too much angle, on all knife types (when i was sharpening without the guides)
I would put too much pressure on the belt with the knife
I would not have adequate light
I've improved a lot since then and can sharpen a knife faster and better with a lot more control, after just 4 days and about 15 knives, from butter knives to 5160 customs
It's easy to understand why i was holding at too much angle, i didn't realize that not only is my knife blade angled, but the belt itself is also angled AWAY from the blade, it's easy to think you barely have enough angle from belt to edge, but when you look from the profile and notice that not only your knife is angled but the belt is also, only then you realize why it takes so long to sharpen an edge and why I couldn't be consistent.
Putting the blade closer to the belt, putting less pressure on the belt improved the sharpening time and with much better results.
Also, standing up with blade in hand, Work Sharp on an elevated sturdy surface will also improve your learning time. Sitting down tends to leave your elbows resting on your knees, moving side to side is harder and with less control when your elbows are glued to your knees, not easy to do smoothly. Much easier to accomplish while standing.
I think the hardest thing is learning what to do when you get close to the tip of the knife. Only after you grind off the tips on a few kitchen knives will you know what needs to be done as it is hard to explain otherwise.
I think a good overall way to start would be: easy consistent moves, not a lot of pressure on the belt, let the belt do the work (that's where the in - between belts come in handy as you're not trying to put an edge on the knife with the 6000 belt) and free up your arms when holding the knife, don't rest them on anything. I think starting off like that will shorten the learning period. Also, borrow lots of knives from family and neighbors, only those cheap Ginsu knives, don't ruin the tips of their Henckels set
