There always seems to be a bit of confusion on the different generations of XM Folding Knives so the following is a basic summary of the different generations currently:
XM-18 (3.0") - Gen 1, Gen 2 and Gen 3
XM-18 (3.5") - Gen 1, Gen 2, Gen 3 and Gen 4
XM-24 (4.0") - Gen 1 and Gen 2
XM-18 (3.5") - Generation 1 - This is the one that started it all for the XM Series of tactical knives back in approximately February 2006. Rick wanted to take the Gen II Flame design and make a new concept in framelock folders, reducing the weight by using G-10 handle material on the non-lockside to make a working knife that was easy to carry. The G-10 was textured to provide more grip and enlarged the thumbstud to allow for easier opening when wearing gloves. In an effort to improve the rigidity of the G-10 non-lockside, Rick embedded a halfliner of 0.050" thick titanium on the backside of the G-10 that also provided a solid lockup point for the 1/4" barrel thumbstud (which also serves as the bladestop when open). The stop pin when the blade is closed is secured to the frame side and doesn't go all the way to the liner side. The halfliner of titanium extends the full length of the knife providing a solid foundation for the over-sized standoffs. The standoffs are 3/8" in diameter with a 3/16" shaft going through them to the opposite side and then screwed in place by three 6/32 stainless screws. The pivot was designed specifically for the introduction of this knife with a 1/4" shaft with a 3/8" head made from hardened 17-4PH Stainless Steel with a 8/32 screw threaded the entire length of the pivot. The pivot was purposefully designed with a straight slot to allow easy field adjustment. This XM sports Rick's signature "Hinderer" lockbar stabilizer and a titanium clip that allows for tip up or tip down carry.
The name of the knife (XM-18) was derived from Rick who considered the knife an "eXperimental Model", hence XM and the 18 was the name of Rick's unit number at the fire department. The knife debuted in Vegas at a table price of $385 (which is unchanged to this day).
All of the knives were custom hand ground by Rick including the signature spanto grind along with some rarer versions (e.g. hellfire). The blades were offered in both flipper and non-flipper versions. The original G-10 colors were black, orange, blue, green, tan, blue/black, and green/black (and there were some other handle materials like micarta). The titanium handle side was offered in stonewashed, bead blasted (a matte smooth finish) or sand blasted (a darker matte and rougher finish).
General Specifications:
Blade Length: 3.50"
Handle Length: 4.75"
Overall Length: 8.25"
Blade Thickness: 0.165"
Lockside Thickness: 0.165"
Liner Thickness: 0.050"
Overall Handle Thickness: 0.540"
Weight: 5.6oz
Blade Steel: CPM S30V & Duratech 20CV
XM-18 (3.5") - Generation 2 - Introduced in approximately December 2006, the second generation of the 3.5" XM-18 had some of the same design changes as the first generation 3.0" XM-18. This XM now included a full titanium liner with "R. HINDERER" engraved on the blade and the Lockbar Stabilizer disk had the "HINDERER" engraving as well. Carbon fiber scales were introduced as well.
General Specifications: (same as above, exceptions noted below)
Blade Steel: Duratech 20CV
XM-18 (3.5") - Generation 3 - Introduced in approximately May 2008 and debuted at Blade 2008, these were the first knives that had the production spanto grind available (custom hand ground blades were also still available) and towards the end of the third generation, the production slicer grind was introduced. The blade no longer included the "R. HINDERER" engraving, instead, the "HINDERER" logo is now on the Ti handle lockside.
Blade Steel: Duratech 20CV & Carpenter CTS-XHP & Crucible CPM-S35VN & Carpenter CTS-40CP
XM-18 (3.5") - Generation 4 - Introduced in approximately October 2011, this generation of XM-18 moved the stop pin from the old location to other side of the knife contacting the spine side (rather than the choil side) and was the full width extending from the lockside to the liner side. This change would allow for the elimination of the choil and different potential grinds.
Blade Steel: Duratech 20CV & Crucible CPM-S35VN
XM-18 (3.0") - Generation 1 - Introduced in approximately October 2006, the first generation of the 3" XM-18 had some design changes compared to the first generation 3.5" XM-18. This XM now included a full titanium liner with "R. HINDERER" engraved on the blade and the Lockbar Stabilizer disk had the "HINDERER" engraving as well.
All of the knives were custom hand ground by Rick including the signature spanto grind along with some rarer versions (e.g. hellfire). The blades were offered in both flipper and non-flipper versions. The G-10 colors were extensive and the titanium handle side was offered in stonewashed, bead blasted (a matte smooth finish) or sand blasted (a darker matte and rougher finish).
Blade Length: 3.0"
Handle Length: 4.125"
Overall Length: 7.00"
Blade Thickness: 0.140"
Lockside Thickness: 0.125"
Overall Handle Thickness: .425"
Weight: 3.6oz
XM-18 (3.0") - Generation 2 - Introduced in approximately May 2009 (Blade Show), this generation included the same changes as the third generation of 3.5" XM-18 including the production spanto grind (first run) and the production slicer grind (second run) and custom hand ground blades as available. The blade no longer included the "R. HINDERER" engraving, instead, the "HINDERER" logo is now on the Ti handle lockside.
XM-18 (3.0") - Generation 3 - Introduced in approximately May 2014 (Blade Show), this generation included the same changes as the fourth generation of 3.5" XM-18 where the stop pin was moved from the old location to other side of the knife contacting the spine side (rather than the choil side) and was the full width extending from the lockside to the liner side. This change would allow for the elimination of the choil and different potential grinds. This generation saw the introduction of the production wharnie grind (first run).
XM-24 (4.0") - Generation 1 - These debuted approximately October 2008. The handle and lockside are titanium with hand ground blades (variety of finishes). There were only ten of the first generation XM-24 in all Ti with the Maltese Cross. The "HINDERER" logo is was on the Ti handle lockside. Due to the added heft of the blade, the stop pin was the full width extending from the lockside to the liner side.
Blade Length: 4.00"
Handle Length: 5.625"
Overall Length: 9.125"
Blade Thickness: 0.185"
Lockside Thickness: 0.185"
Overall Handle Thickness: 0.590"
Weight: 7.8oz
Blade Steel: D2 Tool Steel
XM-24 (4.0") - Generation 2 - Introduced in approximately June 2010 (Blade Show), this generation included the same changes as the third generation of 3.5" XM-18 including the production spanto grind and the production slicer grind and custom hand ground blades as available. The "HINDERER" logo is on the Ti handle lockside.
Blade Steel: Carpenter CTS-XHP & Crucible CPM-S35VN
Credits:
If anyone has anything they would like to see added, send me a PM and I'll do my best to incorporate it. This will be a work-in-progress so please give me some time to work on it. Any errors or omissions, don't hesitate to contact me.
Gen1 - The G10 handle is reinforced with a full titanium liner. Hand ground and "R. HINDERER" engraving on the blade. Lockbar Stabilizer disk has the "HINDERER" engraving.
Gen2 - Blades are either hand ground or CNC'd but NO more "R. HINDERER" engraving. The "HINDERER" logo is now on the Ti handle lockside.
Gen3 - Same as Gen2 except the stop pin is mounted differently (similar to Gen4 XM-18 3.5").
Gen1 - Handle is G10 on one side and the lockside had a titanium half liner milled into the G10 scale. Hand ground and "R. HINDERER" engraving on the blade. Old school barrel thumbstuds.
Gen2 - The G10 handle is reinforced with a Ti liner. Hand ground and "R. HINDERER" engraving on the blade. Lockbar Stabilizer disk has the "HINDERER" engraving.
Gen3 - Blades are either hand ground or CNC'd but NO more "R. HINDERER" engraving. The "HINDERER" logo is now on the Ti handle lockside.
Gen4 - Same as Gen3 except the stop pin is mounted differently.
Gen 1 - Handle and lockside are titanium. Hand ground blades (variety of finishes). There were only ten of the Gen 1 XM-24 in all Ti with the Maltese Cross.
Gen 2 - Blades can be either hand ground or production. The "HINDERER" logo is on the Ti handle lockside like the Gen 3 3.5" XM-18 (and they are otherwise consistent with the Gen 3 3.5" XM-18).
Blade Length: 3.50"
Weight: 5.6oz
Blade Length: 3.0"
Weight: 3.6oz
Blade Length: 4.00"
Weight: 7.8oz
Credits:
- Photos courtesy of Rick Hinderer Knives (http://www.rickhindererknives.com), Rob Orlando and Josh Bryant
- Most of the information was gleaned from Rick Hinderer, Rob Orlando and Mike Kammer via conversations and public posts/comments.
