Thanks, Jerry.You are both correct. No chips are missing from the edge but there are parts of the edge that were dented, ground down, or bent by the abrasiveness of the concrete. They are deep enough in some places to require some re-grinding in order to have a smooth edge once again.
Steeling that edge would dramatically help and would definitely provide a usable field edge. You could then use my favorite trick that was taught to me by my Dad when I was a kid. He showed me how to strop the edge of a knife blade along the top of a side car window! It is pretty much like a ceramic stick since it's made out of tempered glass and rounded. You only use this trick if your edge isn't too ratty!
Let's Drink!
Jerry
From my standpoint, there are 3 areas where blade toughness is often measured that translate into real-world performance. Those would be the ability to resist high lateral forces on the entire blade without plastic deformation, the ability to endure impacts on very hard media without losing gross use of the edge (like in your vid above) and the ability to cut through moderately hard media with a much lesser degree of damage to the edge.
INFI really excels in the first context. A practical example of that would be batoning a tough piece of wood with a large knot, and having the blade flex on its way through. And as you say, INFI is also very good in the second context, where it's a given that the edge will be seriously compromised for finer cutting, but field restoration to a level where it can still be used for general cutting tasks is relatively easy.
The third context is where I would be most interested to see a comparison between INFI and SR-3V. Nathan Carothers has posted a few vid's on this over the years, notably featuring a Bushwhacker Mistress as his control. He uses a variety of blades to cut nails and bolts. INFI also does very well here, but optimized 3V gives it a pretty good run.
The Free Rein performs very well in your bolt cut video. So what I'm interested to see is the performance tradeoff in these areas between INFI at 58-60 vs. SR-3V at 61-63, or perhaps even INFI at 61-63, with the same blade model. If SR-3V (or both steels at higher hardness) do better in the bolt cutting test, what do we have to give up from INFI at 58-60 to get that?
My guess is that ultimately it will be a question of higher extreme edge stability vs. greater ease of gross edge restoration (and maybe a bit more corrosion resistance).
