Got this in yesterday, haven't seen much chatter about it here.
PROS:
In that last photo, looking at the detent hole, around 10 o'clock you can see a little bright spot on the edge of the hole - that's the chamfer catching some light. It's tiny.
PROS:
- Same size in the pocket as a Leek, but comes with a deep carry clip and has a longer blade with better steel, grippier in the hand and lighter at least compared to a stainless framelock Leek, no assist.
- Super sharp out of the box
- Quality is spot on, I can't find any machining imperfections anywhere. Blade perfectly centered, even grind on both sides of the blade, etc
- Not quite fall-shut, but just give the blade a tap and it'll drop shut.
- I like that the bolts for the clip are countersunk so they're not sticking up taking up space
- Personal preference, I'd prefer a stonewashed or acid etched clip. I know the shiny polished finish matches the hardware on the knife, but I like more subtle clips that don't draw attention to themselves when the knife is in my pocket. I may de-polish it at some point...
- The detent was STIFF. No, I wasn't holding the lockbar. Coupled with the aggressive/sharp-ish jimping, it hurt my finger to open the knife. I set the pivot as loose as possible without any blade play and fiddled with it (opening and closing) for a good hour and a half or so last night and it didn't loosen up or wear in any. So this morning I put a teeny tiny itsy-bitsy chamfer on the detent hole in the blade (used a cone-shaped grinding bit on a Dremel, and a very light and quick touch to the hole). Much better now, still a bit stiff, but doesn't hurt to use the knife, and deploys reliably every time. I can shake it loose if I try really hard, but you've really got to sling it around hard, it ain't coming out on accident. I don't recommend trying that yourself...but if you do, baby steps. I can just barely see the chamfer, can't really get it in focus w/the iphone camera (attempt below) and that's all it took to make a noticeable difference in the action.
