It's too bad a few of you guys have experienced issues. I've bought 15 altogether and only 1 of them had any play that I would consider abnormal, there's going to be some play with a linerless and riveted knife.
I could not agree more. My older 110's (circa 1967, and circa 1981 or so) are both as tight as bank vaults. Even after all of the junk I have done to those knives, the chipped edges, torquing, and etc. they are still very tight and strong. I know Buck is capable of making a fine knife without any blade play in any direction that will stay that way under demanding use.My 2 cents...
Buck rose to prominence with their strong fixed blades and then grew even bigger with a folding knife that they sold as performing like a fixed blade - the 110. We are reminded that strength is the core of Buck's identity every time we see the anvil logo, as it's a reference to the old bolt cutting adds (that I'm old enough to remember).
IMO, blade play undercuts Buck's identity in ways that purely aesthetic and non-functional issues (e.g. centering, mis-matched scales) do not. I think this remains the case even at the low $25 price point and its much worse at the $100 price point.
Perhaps I have high expectations but I'm very confident that Buck can produce lock back knives in the US in the $25 - $100 price range in which blade play is a rare exception and not something that we more or less expect (i.e., "there's going to be some play with a linerless and riveted knife").
good point. most of the play is so minor it has no effect on using the knife as a knife. only annoying to a collector. used hard enough and long enough, all knives will develop some play over time.I agree excessive play would be a warranty issue. But what control do you have with riveting a blade between 2 pieces of micarta. There's no screw type adjustable pivot to eliminate play. I handled plenty of brass 110 with the same or worse blade play than the slim models I bought. I didn't sit there at the counter and open up 15 boxes to check for imperfections. I trusted they would perform to exactly what they were designed for, Only 1 of the 15 had excessive play.
I'm giving credit where credit is due. Buck did well on these.
The Bantams are built the same way but since there was no Brass version to set the standard expectations arent as high.
I agree, but may have a bit different take. The standard 110 was intended as a folder that could be used in the field to dress an animal. That holds true for any 110 with a liner. The slim version with the clip, in my opinion, is intended as an everyday carry option. Blade play, while an important issue, is not as important for an EDC. (My opinion) For a folder without a liner, I am more than satisfied with the solid lock on the ones I have and plan to use them in my EDC rotation.The materials used are Micarta. No liners. Without liners their is only so much stability in the design. Expectation have to be realistic. you know as well as anyone on here that there is the same blade play in the Standard 110 knife now and again. The Bantams are built the same way but since there was no Brass version to set the standard expectations arent as high.
I really think these new pro knives from Buck are a game changer. Wish they would have done them 20 years ago...I am just very happy with the thin edge, almost scalpel like, and the ease of carry with the clip and the lightweight construction- compared to the heaviness of the original 110/112.
I think you nailed it. what is significant blade play? i know what I think it is. we all seem to have different guidelines and tolerances on the topic. a tiny bit to me is significant to others. what I consider significant is minor to others. rarely do folks measure the movement when discussing blade play. so we are stuck using our own terms to interpret what they discuss.I would disagree with your opinion regarding blade play.
To me, it does not matter what use I have for a folder, blade play is an issue. A knife that is well constructed will not have significant blade movement, either lateral or vertical.
