- Feb 17, 2009
... if you have variable speed, go slowly. Use marker to markup the blade and eyeball after each pass - the shiny parts are where you grouind it off.
This,
Sharp belts, slower speeds and to cut down on mistakes and as mentioned use a sharpie to see what and were you are at.
You are building a pyramid when grinding, you start at the top and work your way toward the base with small passes, lay down a grind line following the edge, then lay down another directly under it. Keep moving the pyramid to the base.
When the your grind meets the top line and the bottom line on both sides the angle is the same on both sides.
