rexromic
- May 28, 2011
No,just my thoughts..The main pitfall is probably being dragged down into the gutter (aka the discussion) with the rest of us
Is this a response to my post?
Larrin, do you have a article about PM60 superclean? If not, what are we thinking about it, similar to Maxamet? Thanks!Maybe the higher hardness is more desirable for avoiding deformation than it needs the extra wear resistance. Or maybe it’s placebo. I will say many Blue Super kitchen knives have chipping issues.
That is an alternate name for ASP 2060 or Vanadis 60. Yes it is in the same ballpark as Z-Max/Rex 86 or Maxamet.Larrin, do you have a article about PM60 superclean? If not, what are we thinking about it, similar to Maxamet? Thanks!
Yes, that is my experience in casual comparisons of 14C28N (a 3 in Larrin's tests) with steels such as S35VN (a 5 in Larrin's tests). For example, a Ruike Hornet seems close to a Cold Steel Ultimate Hunter. Or maybe I'm rougher on the Ultimate Hunter after seeing Joe X.Obviously, heat treatment matters. Lots of companies seem to run 14C28N on the softer side, like 55-58. Luckily, it doesn't seem to take as big of a hit on edge retention from being run a little soft versus M390, S35VN, etc. Lots of production knives in super steels have a target range of 58-60HRC, which is already on the low side for their optimal edge retention. Sometimes, they come in below that target range (and there can be other issues). So if you are comparing the average budget knife in 14C28N and the average $150ish production knife in S35VN or M390 with the respective edge retention ratings for those steels; the super steels tend to fall far short of expectation while the 14C28N may be surprisingly okay by contrast.
With appropriate geometry you can do all sorts of interesting things. When people talk about slicing edge retention they mostly speak of wear resistance, but of course in general whatever makes the edge duller, be it chipping, deformation, wear, corrosion play a role in what end users perceive as general edge retention.I tested one of my 5160 blades batoning it through a 3/4 Bolt 3 times and the edge never chipped or rolled and remained just as sharp as it was before the test ~ is this what you would call edge retention ~ I'm not sure on the terminology ~ although I see you never mentioned 5160 at all ~ I myself was surprised what carbon steel can do and that I thought it was pretty amazing ~ myself
You’re the manRecently I was able to acquire a used CATRA machine, so I heat treated just about every knife steel I had, made 57 knives with the help of knifemaker Shawn Houston, and tested them all to see which cut the longest. For a few of the steels I did multiple heat treatments to look at a couple variables and to see the effect of hardness. I also compared edge retention and toughness to see which steels have the best balance of properties. https://knifesteelnerds.com/2020/05/01/testing-the-edge-retention-of-48-knife-steels/
That’s one of the great things about 14c and why it’s a great budget steel. Honestly, I seek out knives in 14c28n and Nitro V and prefer those two over most premiums steels. Luckily for me, that also means the knives usually don’t break the bank.Yes, that is my experience in casual comparisons of 14C28N (a 3 in Larrin's tests) with steels such as S35VN (a 5 in Larrin's tests). For example, a Ruike Hornet seems close to a Cold Steel Ultimate Hunter. Or maybe I'm rougher on the Ultimate Hunter after seeing Joe X.
It would be fun to have a hardness tester.
