I like to use a 10X magnification eye loop to inspect the edge while sharpening.
Very easy to observe small burrs and for my free hand sharpening, some burrs are local for a short length of the edge and other areas are incomplete apex.
It also shows where you have not reached a true apex along the final edge.
Years ago I attended a woodworking show that had Haroldson Stanley as an exhibitor.
He is the USA distributor for Shapton stones and I requested he sharpen my Benchmade 812, I really wanted to see his technique.
He explained burr formation and the problems with tearing it away with wood, cork or leather stops.
He also had a USB microscope set up with a computer screen,,, very interesting.
Stanley recommended removing the burr with your finest stone, use very light pressure or no downward force at all,, and run the blade at 90 degrees down the stone for one short stroke,,,, observe the burr or lack of burr.
Then make a few passes with again, very light pressure to further refine the edge at your apex angle.
The torn away burr was easily seen under magnification and cutting away the burr with the stone then further refinement showed nice improvement.
Some recommend as a final step, forming a micro bevel which may or may not remove the burr with abrasive cutting. I believe it just rolls the burr to the opposite side, it becomes smaller and with some steel alloys, very difficult to completely remove all of it.
One technique I like is to charge a hard leather strop with diamonds,, this does cut away the burr and leave a highly polished edge which is somewhat convex.
Cliff Stamp claims the edge has deformation of the steel under the actual apex after use,,, he cuts away that week bond with a few light stokes, 90 degrees, at the beginning of his sharping cycle. The deformed edge is ragged and weak compared to the tougher steel below,,, we are talking of a very small amount of steel removal, not like the YouTube guy that runs his blade down a brick at 90 degrees for 20 stokes, then proceeds to sharpen.
Regards,
FK
