- Jul 10, 2017
Is that single beveled ?
Yeah. Single beveled.
Here's a shot from the top.
Its good for flattening two sides of a stave so you can draw a pattern.
Also the flat top is good for checking for flatness as you work.
That's cool, it looks much more attractive than the typical broad hatchet with lugs on top and bottom.Yeah. Single beveled.
Hmm, that's something.I think Plumb marketed that style as a 'flooring hatchet'.
Adds I grabbed from somewhere on the net. Left is supposedly from 1940 (dealer unk), right 1955.I think Plumb marketed that style as a 'flooring hatchet'.
Vaughan makes a 22oz half hatchet with a regular hammer poll which they call a flooring hatchet.
I wonder if the broad single bevel format offers any advantages.
IDK, hewing is done with both single and double.
From post #4105: "Used by carpenters for squaring up light lumber".
Bob
Garry3 let me save this riggers axe from being used as a wedge, and here it is as I got it.
I've recently seen an identical Vaughan,that in addition to a "wear safety goggles" stamp on the right side also sported a welded-in bit...I didn't realise that these two things were concurrent...
Any idea of a time period in which it was manufactured?...(even if only approx.)
Thanks in advance...
Here it is after rust removal and bit re-profiled.
I have no use for a riggers axe as they're meant to be, so I plan to hang it at about 20-22" on a curved handle.
It'll take some doing to find a suitable handle , but when I do I'll post it in the hanging thread.
The single bevel allows you to take thinner cuts without the the bit skipping off the work. I enjoy them.Hmm, that's something.
Yeah I knew that, I was just thinking about why Vaughan may have decided to make their flooring hatchet a double bevel.The single bevel allows you to take thinner cuts without the the bit skipping off the work. I enjoy them.
Only advantage I could see is that it would make it ambidextrous.Yeah I knew that, I was just thinking about why Vaughan may have decided to make their flooring hatchet a double bevel.
The addition of wear safety if a fairly modern thing ( I think some time in the 80's ) and for the longest time Vaughan and Bushnell tools have been drop forged from 1080 steel so I doubt this riggers axe has a forge welded bit.
Why do you say it had a force welded bit ?
Without a picture though I couldn't really tell you much, not that I'm really an expert or anything.
Vaughan dunks their heads in a quenching solution, and this looks to me like it was pretty agitated when the head got dunked resorting in the wavy line. I don't know why yours has the color it does, but it's definitely made of one piece of steel.Thanks for your thoughts.Here's a photo:http://imgur.com/a/RorIw
What makes me think that it's not a "temper line" is 1.,that it's wavy...(and it's not like they'd clayed it up at the factory...).
2.,that even at an unlikely event that it is some HT event,the color is all wrong;while it's just right for a contrasting,higher-C insert(the higher the C content-the darker;while the hardened part most commonly would be lighter colored....)
And lastly,to make the differential HT appear visible to the naked eye it takes a rather high degree of polish,1200 grit and up,i'd say,minimum....
So i'm frankly puzzled,and it brought up this question in my pea-brain:Untill then did the US manufacturers resorted to composits in axe-making?
(sorry,it's probably not the best place to go into all that...)
IMG_20170806_095123 by Justin Lyttle, on Flickr
You may be right about the uneven heat.Thank you,but i'm having a tough time seeing it happening....Splashing of a quenchant cannot result in an uneven line of HT...(i THINK i'm fairly certain of that...An uneven heating may....however likely that may be in a factory setting(a rack of tools travelling through a gas forge....) )
And,again,any Martensitic formation would appear as light-colored,and only at a very high polish...
This dark,visible at grindstone/file finish edge is either a different C-content alloy,or it's something tricky,like Nitriding,Boriding,or some other similar treatment...
I could easily be entirely off,ferrous metallurgy is full of surprises...
