Such as? It's hard to recommend a multitool without knowing what your regular use cases are.
Currently I work at Lowes as part of the pro services delivery team. Most of my job entails pulling large contractor orders and assigning them to flatbed trucks for delivery.
Work sees a lot of knife and box opening. Some light-medium prying. Pulling big/sometimes busted staples out of lumber. Occasionally installing product or at minimal re-tightening.
So tools I’d see myself using most are good set of pliers, knife, prybar, screw driver (Philips and flat) obviously we have a full range of tools in the back. But a carry MT to grab, verses walking all the way to the back anytime I need pliers or something.
If that background helps haha
In steps a Leatherman. Carry one item on a belt sheath not 4 different tools. Leatherman wave+ has a decent size flathead screw driver that can easily be modified to use as a pry tool. Especially since it has a bit driver. And it’s blade is sturdy enough to pry small things as well.Based on this it looks like you need an ordinary inexpensive box cutter and an EDC prybar. Opening packages is horrible on a knife. This is what box cutters are made for. The blades are cheap and can be easily replaced as often as needed.
If all you need is a set of pliers and a bit driver, then something like the Leatherman Skeletool may serve you well enough. It has pliers and a bit driver with an outside opening combo edge knife. I've never been a fan of the flat proprietary Leatherman bits though. They're too soft and they've been often hard to source in the last few years due to supply chain problems.
If I were to create the ideal multitool for you based on your criteria, then it would have a quarter inch bit driver, pliers, a replaceable blade (perhaps a scalpel holder) and a heavy duty flat screwdriver for prying. It would look very similar to the Havalon Evolve, which is itself a kind of clone of the Skeletool.
There's no perfect multitool for you but that's probably not what you want to hear. I would carry a box cutter, a prybar, and any multitool with a set of pliers and a bit driver.
I’ve kinda eyeballed the SOG PowerPint. But reviews seem too divided. Either you love it or hate it.From the sound of your intended usage, I think the wave or rebar is what the doctor ordered. If you do much assembly or installation at work you will find the knipex very valuable also. You sound like a perfect candidate for a regular Leatherman tool to me. Enjoy
That's the multi-tool that rides in the door of the camper van. Knipex is always on my belt and an SAK compact in pocket.I like the gerber centredrive. It has a bigger blade, one handed pliers and the bit driver takes normal bits.
Used to have one myself. Won it from a army kid in Africa in a poker game. Never cared for the slide openThere's no better tool for plucking ear hairs. No idea how old it is but it's the military issue from OIF. It's given me 7 stitches before. Cutting a wire harness at a junk yard. Painted it orange years back...because why not?
Gerber
img hosting
Oh it’s a tank. I liked it. But much prefer the flip opening of a LeathermanIt's definitely been used. The wire cutter triangle has never been rotated. Still going strong. Both blades are still sharp.
What impressed me, I tried to security engrave it. Using one of the vibrating tool scribes. Whatever steel they use. It's remarkably tough. Almost tore up my engraver and it still didn't mark worth anything.
Yeah, no that's actually wrong. Turns out that opening cardboard is pretty harsh on a knife. This is the whole reason box cutters exist in the first place.cutting tape and cardboard is not bad for your blade
Right? Bond is about $60 new. Rev is $40-50 new. Nothing super fancy. But solid $50 score for sure.Nice find. I wonder what the pawn shop paid for them. It must have been robbery.
And you can always use an extra! Nice find.Right? Bond is about $60 new. Rev is $40-50 new. Nothing super fancy. But solid $50 score for sure.
Plus it’s two decent offerings. I can spend time with both and see what I like/don’t like or what I use/don’t use.
Right! I’ve had a Leatherman Free T4 the little magnet one hand hope until knife one. It kinda gets tossed around and used occasionally. I pulled it out when I got home. And man the Rev offers more and is just a hair bigger. And that’s even with the pliers.And you can always use an extra! Nice find.
