Lemmuhj,
Two things I notice right away.
The holes in the washer are much more open than the 25, I thought the Inkosi was going to be more resistant to fouling because the holes were not open, clearly not the case. That is disappointing.
Second thing, the chamfers are much different. I will get some pics tomorrow.
It appears the chamfering where you disengage the lockbar on the Large Inkosi is the same as on the 25 and does not mimic the lockbar chamfering on the Small Inkosi. Is this correct?
Id say thats correct. There is some chamfering on the spine of the scales which gives the whole knife an "hour glass" shape. Not too crazy about this as it makes the knife "skinnier". Im trying to get used to it as the 25 was fine. Overall, i like the changes. Still looking forward to someone posting side by side comparison shots.
Couple questions I have:
Is the stock thickness the same as 25/umnum or thinner?
Is the grind more "hollow" as mentioned?
"Friends don't let friends use pocket clips"
"Clips are for wimps"
Inkosi with clips removed and clip inserts inserted.
Not sure on thickness...seems about same. It does seem the grind is a little more "hollow". Looking forward to some side by side pics with the 25.
As for the clip...i may be riding with a "Congo Clip" soon...i feel a slight hotspot that is bugging me.
Here is a video I did on my YouTube. I referenced Justin's first post in the video. I'm sure those with a more keen eye will find some differences I may have missed.
https://youtu.be/r-PbKqHj8fo
Sent from my XT1575 using Tapatalk
No problem at all!Going to watch it now. Thank you for making it. Are you OK with me posting a link to it in the OP?
People are going to ask, so I will just do it now, which clip inserts did you use?
