- Aug 22, 2005
Well, it should be easy to test... Run side by side thin vs thick edge with same steel. May be I'll do this sometime.
Thanks, Vassili.
this would be good test, to see if the edge type does make a difference as well as the thickness of the blade near the edge. I think the results will differ because as you were down the edge the thicker knife has more surface area making it harder to cut with, just what makes sense to me, anyway.
