- Oct 18, 2001
THIS IS NOW AVAILABLE FOR PRE-ORDER
http://www.bladeforums.com/forums/showthread.php?t=530749
Ok, you guys know the drill. :thumbup:
Here's what I've got so far:
See Design #3 here:
http://www.bladeforums.com/forums/showpost.php?p=5295584&postcount=69
Specs on the above:
Overall length = 16 inches
Blade
Ring is 1 inch diameter
For now, the sawback is a no-go. Might revisist that later on if there's enough interest.
#1 has more of a drop point
#2 has a staight clip
Design intent:
Here's my reasoning on this guys...
I was looking at my WSK in one hand....and my K-BOAR in the other hand....wondering if there was some way to "bring the two together". The K-BOAR is such an efficient pig-sticker, but I would be leery to use it for chopping. The WSK is an excellent chopper and can be used for draw-knife cutting as well (the K-BOAR has a sharpened top edge).
So, I set out to design something that would have the best of both designs. Be able to "take a hog" with the blade, but also chop, baton and draw-knife with it too.
Right now...I'm leaning more toward design #2. Can still be used for batoning, yet the swedge (not sharpened) allows good penetration.
Also, I'm sticking with 1/4" thickness for now. I looked at it in cross-section and don't feel the gains in balance offset the loss in strength.
Additional notes:
Yes, this is "almost" a bowie knife. But there are some key differences.
The most obvious is the use of a ring instead of a guard. The ring does act as a guard and, if you compare it to a guard/subhilt....or a guard/choil combination....the ring is stronger - more steel "connected" together. Make sense? No welding...no hidden tang to break off....no choil to weaken the blade cross-section. It is essentially a 2.5" tall piece of steel with holes in it. More sturdy....stronger. Retention is also excellent. There is enough room to fit your entire hand behind the ring...the ring is mostly for "choking up" tasks...just like a choil. :thumbup:
The other obvious difference is the flared butt of the handle. This a big departure from "traditional bowie knives" - that might have a coffin-shaped handle, or even just a piece of stag. Look great, but retention is not a strong-point. My inspiration for the handle butt is clearly the Kukri (ie. http://www.qcmilitaria.com/ind/kukriN.jpg). The hand fatigues easily during chopping and losing your grip (safety lanyard or not) is no fun. The flared butt in the handle allows you to use even just 2 fingers and your thumb to "hold on" while chopping.
Well...there is probably a lot more to say about this...but I've run out of steam...
Tell me what you guys think and we'll take it from here.
This is NOT a pre-order thread.
But feel free to express your desire to have one.
And yes, pricing will be $195 :thumbup:
Dan
See Design #3 here:
Specs on the above:
Blade
- 9 inches (sharpened), 10 inches to the front of the handle
- 5160 steel, hardened to ~59.5 HRc
- 1/4" thick
- 2.25" tall at the belly
- Flats will be "as-forged" finish
- "K" logo will be
cut in by waterjetetched
- 6 inches (from front of the handle to the pommel)
- 5.5 inches of actual handle material
- 1/4" thick material (0.75" total)
- Options would be natural, green or black canvas micarta
- 3 lanyards/tie downs (front safety lanyard = 1/4", rear handle lanyard = 3/8", pommel lanyard = 1/4")
- 2 Corby pins (mechanical fasteners)
- Handle is large enough to fit an extra large hand "just right". The rest of us "non-apes" will have some wiggle room - helpful in chopping.
Design intent:
- Large Camp Knife
- Able to handle chopping, batoning, heavy-duty food prep
- Pointy enough to sley wild beasts (hogs come to mind )
- Heavy enough to chop, but not "pants-pullin-down" heavy
- Tall flat grind with 0.025-30" thick edge for strength, yet great cutting ability
Additional notes:
Dan
