gk4ever2
- May 1, 2008
Quite right. After witnessing all the mods done to $400 Busse knives I guess I need to step up and not be afraid to try one on my $100 esee6.OK, so round file and a respirator right? Can't find any video tutorials on it on YouTube, I could find some "after" videos but none of the complete project in the Busse style. Anything to be aware of?
If you have access to a belt sander it would make the job a lot easier. hhmoore mentioned a Half Round file, much less of a curve in those, a round file will try to dig in too much and cause valleys. If you dont have that and have sand paper just make a sanding block out of paint sticks. Start with a heavy grit and go lighter as you cut away material.
Hope this helps a little. Just basic ideas, you might have to fill in some blanks.
EDIT to add: If you get cloth backed sandpaper simply tear it into strips and carefully mount the handle scale in a vise then act like your polishing a shoe!
If I chose a file, it would be a flat one. I like Dwayne's ideas about sandpaper the best. Definitely use a respirator.
Remember, it is better to remove a little at a time, see how it feels in your hand, and then remove some more if needed and keep repeating this process, than to overdo it and take too much off.
