- Mar 2, 2013
Speaking of delaying our gratification, I've tarred my handle on this kirves of Finland strung up now curing in the hay loft. It might be handleable come spring-time with any luck.
I see your point. It was worth a shot anyhow and I'll let you guys know how it holds up. I was thinking there's enough solid haft behind the repair that it wouldn't be an issue. But I've thought that before and been wrong... I guess if it fails I can always remove a crap ton of wood and hang a Hudson bay pattern on it.I think you're asking for trouble with that fix. The wood fibers in that part of a helve are in tension not compression. It will likely fail at the bottom of your 'dutchman'.
Beautiful work!Got it finished! Quite a few photos with this one. I used scraps that were left from the 41" db haft I made for the plumb Puget sound falling axe.
Here's my first pic;![]()
Here I had hung it and had just cut the excess off the swell.![]()
Here it is finished without oil;![]()
And all done;![]()
I have to say I'm pretty pleased with it. Even thought it's thin the swell is plenty large enough and it feels good to swing it. Also it has a full 2" eye! On a small hatchet like this!? It's awesome that thing is never coming loose! It's a good little chopper. Thanks for checking it out!
Love it! I really want to make a few handles, it’s been a while. Just haven’t hade time lately. Beautiful work!My procrastination means I have some pretty deep checking. But I can work around I think. I've since roughed out both 31" blanks. Some photos of the first one.
I used my chainsaw to cut that in half this time. It's been seasoning for a year and I wanted it perfectly in half.
I flattened both sides.
And traced out the haft;
And got to work on it!
I knocked the thickness down next;
Then used my large wood rasp.
I then (the horror) switched to my belt sanderto smooth it up.
It's still pretty thick and needs a bunch more work. The other one I shaped with just a little more curve but isn't this far along. Anyway been awhile since anyone posted to this thread!![]()
Thank you man! I remember at the start of this thread (I think anyway) you had a bunch of staves drying. You think you'll find some time to make a few?Love it! I really want to make a few handles, it’s been a while. Just haven’t hade time lately. Beautiful work!
That's a beautiful handle! Do you have a head lined up for it? I'm laughing at how similar our handle making processes are, right down to the hewing hatchet. I'll have to post the progress pics of one I just finished. They're eerily like yours (although mostly inside with bad lighting).My procrastination means I have some pretty deep checking. But I can work around I think. I've since roughed out both 31" blanks. Some photos of the first one.
I'll be curious to see how that holds up. I was thinking about it and (if I read square peg's concerns correctly) can see how it might appear to be under tension, but from a physics standpoint (granted it's been 20 years) by the time the head hits wood, there shouldn't be a lot of force applied to the handle, it should just be inertia driving the head into the wood. Of course end grain gluing isn't as strong as the other way... Yes, very curious to see the report.I see your point. It was worth a shot anyhow and I'll let you guys know how it holds up. I was thinking there's enough solid haft behind the repair that it wouldn't be an issue. But I've thought that before and been wrong... I guess if it fails I can always remove a crap ton of wood and hang a Hudson bay pattern on it.
