I just think the expense is too high for newer steels really, like the difference in performance dosn't reallys hine througha s much as the difference in cost.
Yeah, you're quite right about that. There are plenty of very expensive knives made from old(er) alloys, but that doesn't seem to be a concern
I am pretty sure someone posting test results of 90deg bending wouldn't get much of a credit here on BF either.
You Do understand that toughness is a desirable trait in knives? Why do you think INFI, 52100, 3V, L6 and the 10xx series is so popular?Aside from western fillet knives, why exactly do you wanna bend the knife?
By the same token, any fool using 1095 doesn't mean he/she HTed it correctly. Somehow, whenever we have debates about old and trusty steels vs. new superalloys, the old ones automatically get best possible HT(perhaps because it's simple) and new ones are assumed to have crappy HT. Not a valid comparison at all.
Familiarity and simplicity. It's not the old ones that get the best possible heat treat, it's the steels that an individual has treated 1,000 times, testing dozens of minute variations, with feedback from decades of use. Is it really that hard to understand why Gil Hibben still uses 440?
Dude. Wrong guy to question about understanding steel.![]()
Nope, that's not true.newer steels make better knives.
Very much so. And on top of the alloys you listed, I can add that toughness is very desirable trait for the light use knives, with very thin edges and high hardness. helps a lot with micro chipping. Vanadis 4E and CPM 3V being very good examples of that. 3V as usual gets mentioned or used for large blades, but it performs very well at 62-63HRC with 10deg per side edges.You Do understand that toughness is a desirable trait in knives? Why do you think INFI, 52100, 3V, L6 and the 10xx series is so popular?
I did mention that old stuff is easier to HT and produce. I agree on both, familiarity and simplicity, but that's the benefit maker(s) get, not the users, what the user gets is subpar performance and lower cost. And the reason Gil Hibben still uses 440A is profit. It is a lot easier and more profitable to produce 10 cheap knives form very cheap and easy to HT steel then spend 5x time to produce 1 knife which will cost 10x more...Familiarity and simplicity. It's not the old ones that get the best possible heat treat, it's the steels that an individual has treated 1,000 times, testing dozens of minute variations, with feedback from decades of use. Is it really that hard to understand why Gil Hibben still uses 440?
Agreed, but during normal use, average user is far more likely to accumulate 700 rops cuts equivalent of cutting, than bend a knife for 90deg. It's not that easy physically after allNobody is going to bend knives at 90 degrees on a daily basis, but they're not going to sit down and repeatedly cut a piece of rope 700 times either.
Edge retention, at least in human held knives is a combination of many factors, not just wear resistance.If edge retention was all that mattered, we wouldn't have steel blade at all. Stellite, and ceramic would are a few examples.
I'll agree with you there, Hevy DevyNope, that's not true.newer steels make better knives.
Toughness, edge holding, stain resistance, grain structure you name it the new "super steels" do it better than the old standbys. I don't understand how there is still debate about this. There is no magic here, all of these claims can be, and have been empirically tested.
There's nothing wrong with improvement. I'm going to play devil's advocate in my post to make a few points. The challenge is selecting the best material for the task at hand. A number of factors decide what the best material is for the particular task. Newer alloys can have some pretty extreme properties, some have a great balance between toughness, wear resistance, and edge retention. Older alloys can have great balance as well. Cost is a factor along with the blend of properties that the material possesses.
Look at costs with the percent difference. If a knife with steel A with a good blend of attributes costs $100 and the same knife with steel B has better overall attributes offering performance gains, but it costs 300% what knife A costs, is it worth it? That depends on the needs of the purchaser and his or her budget.
So while 1095 may not be the toughest steel or have the highest edge retention, it does have a desirable blend of properties for many uses and it's not generally super expensive in comparison to other steels. There are many great alloys, but often they come and go in popularity. ATS-34 isn't used much anymore. 440C isn't used much anymore. Calling new alloys "flavor of the month" is fairly accurate. Many alloys come and go. Some remain popular and stick around for long periods of time. A steel like 1095 is proven and is a pretty great choice for many knives, from small slipjoints to larger fixed blades. Usually it's relatively inexpensive in comparison to knives made out of newer alloys like 3V, M390, etc.
I don't see a ton of people bashing new steels. Mostly I see people unwilling to pay a lot more money for, and let's be honest here, an unknown % increase in performance in various properties of the material. There is no chart that accurately reflects all the variables for toughness, edge retention on tons of materials, etc. and compares dozens of alloys to show performance ranking in real world environments.
There are too many variables to accurately and decisively measure performance of all the alloys out there: too many grits/finishes, bevel angles, inconsistencies in materials cut, lateral forces (user error, fatigue induced, tendency of the material to cause lateral force, etc), and the myriad of other variables.
So in reality no one can really say that knife B performs x% better than knife A in even one category. At best we can try to form a general sense of performance after doing a lot of testing and use, and maybe we can come to see how various steels can perform under a specific set of circumstances. It would take a monumental amount of research and testing to accurately compare all steels to come up with meaningful performance data for all around use for the general knife user.
In the end I think that many modern alloys are excellent and do show excellent performance in particular areas and many are great all around alloys. CPM-154 seems to me to be great for all around use, but I honestly have no idea how it actually compares to S30V, D2, VG-10, S110V, or 1095 if I had to come up with real, concrete % differences. The majority of what is discussed on this site with regards to performance is based off of gut feeling, experience, and/or possibly placebo or bias rather than rigorous scientific testing methods.
Let me play devil's advocate here: When it comes down to it who is able to answer even a relatively simple question like "For edge retention how does 1095 finished at 1200 grit at 20 degrees inclusive at .005" thick behind the edge compare to S110V finished at 600 grit and at 30 degrees inclusive at .01" thick behind the edge while cutting sirloin steak?"
If we can't give actual % differences based on real life scenarios then why do we need to be obsessed with the newest alloys?
The newer steels are better than the old ones, all things being equal. This certainly doesn't mean the old steels are bad. 52100 is one of my favorite steels even though it is technically a dated cutlery steel.
A 3V knife will out perform a 1095 knife in every single aspect.
An M390 knife will out perform a 440C knife in every single aspect.
An ELMAX knife will out perform a D2 knife in every single aspect.
Toughness, edge holding, stain resistance, grain structure you name it the new "super steels" do it better than the old standbys. I don't understand how there is still debate about his. There is no magic here, all of these claims can be, and have been empirically tested.
Someone send me a knife in say 1095 at 64 HRC at .010" or less behind the edge, 5" blade, flat ground with a 1/8" spine to test and I will make a point compared to some of the super steels that I have on hand in like knives on abrasive materials.
I will put a 10 DPS edge bevel on it and cut with it.
And I will show people how fast it goes dull, and it will be very fast when compared to the super steels, there is no way around it..... Even at 64 HRC.....
I made the challenge, it's out there, any takers?
I doubt it.....
Because they already know how it will turn out......
