Huntsman Knife Co.
- Sep 10, 2010
Actually, my reading indicates that 52100 and AEB-L perform better than any more recent steel in "edge stability" specifically because of "grain structure" - these steels, when heat treated properly, present a finer grain structure than any of the powder steels HT'd at its very best. Indeed, they are the benchmark to which the powder-steels are compared. They are cheaper to produce, take a finer edge, take it quicker, and maintain it longer against impact and compressive stress. But AEB-L is superior to 52100 in corrosion-resistance.
CPM-3V will outperform 1095 in toughness, wear, and corrosion; M390 will out-perform 440C in all 3. But how does each of those compare to 52100 in ease of manufacture, maintenance, and edge-stability? Both present better corrosion resistance but M390 is not quite as tough... and MUCH more expensive and more difficult to manufacture. I'm not sure how 3V compares...
Again, I'm not poo-pooing the new steels, just playing the opposing side here. I LIKE the innovation of bringing these new steels to market, especially for certain applications. But the application is key.
If you don't need the ease of maintenance or the edge-stability provided by these "stand-bys", then they are for the dust bin. But these 2 at least are NOT inferior in respect to grain structure.
I use 52100 extensively in my knives and use AEB-L as well. They are an exception as they have the finest grain structures of any steel which is something that makes them perform very well. I absolutely love 52100. I use it in everything from razors to skinners to tomahawks and machetes. Its probably the most well rounded steel out there if you ask me and will excel at everything from fillet knives to katanas.
That said 3V is probably better than 52100 for anything but a razor blade or kitchen knife. It has better edge stability, cuts more aggressively, is significantly tougher at the same hardness and has about 2.5X the edge retention on most things. You can run 3V at 62 and its as tough as 52100 at 57-58.
BUT Its also 3X as expensive and the cost is not worth the increase in performance much of the time. 52100 is amazing and I plan to continue to use it until a better steel comes along at a similar price point.---which hasn't happened yet and probably won't for a long time if ever.
