My technique exactly, there. When rebevelling I'll give in to it, otherwise I try to avoid it like the plague. I find that is easiest done with a microbevel, and can be much more challenging on a full, wide bevel.
Visilly, when I get the time and figure out how to get a picture that visibly shows the hair whittling I will do it and figure out how to post on You Tube. With the ceramics I get my best results only honing a microbevel onto an already sharp edge (usually from a DMT fine stone). I prop my stones up to my desired angle (12-15 per side usually, on a 10 or less per side main bevel), then go slowly and lightly with alternating strokes until I notice that the blade is getting very sharp for the grit, and I check under a lighted Radioshack microscope for burrs. The last 2 knives that I have sharpened to high levels of sharpness (for me) on the ceramics were my Krein in CPM M4 and my Endura ZDP. Oddly, a VG-10 R2 that I sharpened after the Endura ZDP wasn't getting as sharp, but I attribute that to getting tired and lazy. Anyway, with a Spyderco medium finish they were tree topping, and probably cutting free hanging hair but I didn't check. At Spyderco fine (after only 5-8 strokes per side at each grit, by the way on the fresh microbevels) they were really tree topping nice and whittling some hair, but the hair would usually skip some across the edge before it would catch and whittle the hair, and sometimes it wouldn't catch. At UF the knives were easily whittling the hairs and peeling off curls. This is my wife's hair, which is thinner than mine, and like most results it may or may not be as hard to whittle as anyone else's hair. Anyway, usually I have to use 1 micron lapping film to get that sharp after going to 8000 grit Glasstones, but I guess I'm getting a bit better with the ceramics. In the past I had trouble with high hardness steels burring on the ceramics, with better luck coming from Shapton Glasstones. Being lazy, whenever I can get acceptable results without having to use water or flatten stones I will go with the ceramics.
I recently got a Sony camcorder, so I will try my best to figure out how to get it to focus in good on the hair whittling. I am guessing I will need to manually focus that for some sort of macro setting, though I have no clue how to do that yet. And sorry for the late response, I was sending my earlier replies from Monterey on an iPhone and was busy looking at various fish and Monarch Butterflies in Pacific Grove (and also dreaming of my Mule Team knife and soon to be delivered Bester 500 grit stone to maintain my masculinity).
Mike
