BTW about "idiots" - 30 passes or something like this is what was recommended on Sharpmaker instructions (actually 20 for each side).
Thanks, Vassili.
Vassili, as HH pointed out. The key is not the 30 sec. (seconds by the way, not strokes ), but the statement "no matter what state the edge was in". 20 strokes on the Sharpmaker are not going to help much on a really blunt edge. My bad on your technique. I thought you were using another diamond stone in between.
The ceramic rods start at the same particle size, but they are not packed more dense but they actually deform and fuse during the sintering process. Depending on the sintering process they can deform more or less. And AFAIK they are 35 micron particles in the "green" state (before sintering).
I don't think sharpness is only depended on grit size. Whether you finish on 4 micron or 1 micron is not the sole parameter here. I think, how many strokes you take on the final step, how hard you press, how large the gap to the previous grit are all important factors. I know, that if you go from 700 to 10000 (or even 350 to 10000) or 3000 to 10000 you get a completely different edge. On the ceramics, I would also expect that it would make a difference how recently you have cleaned them. And lastly of course, what steel you are honing.
