Interesting! Thanks for sharing.Hi Josh,
Royal Purple makes an oil for firearms. It doesn't seem to be in stock anywhere but I would send some to you for free. I did some partial cover outdoor corrosion testing like 5 years ago and it stood out.
Works in extreme cold. Doesn't go bad. Treat a gun with it and leave it in a locked room for a few years and it will still seem freshly oiled. Seems slick enough.
It isn't food safe but it doesn't scare me like some other products do! If a product isn't food safe then I prefer NON aerosol.
Hornady One Shot hardens like glue after a few years, in my experience.
On the one shot how does it harden like glue? It's a dry lube that you can't really feel... It would have to be on pretty thick to feel anything I would imagine
wow, good to know! ThanksI put ONE SHOT on a test plate that I never ended up testing. I sprayed it on lightly - no wiping. Came back to all my test plates after a few years and ONE SHOT was the only product that needed solvent and scrubbing for removal. It was gummy!
Freshwater board is done and the results are extremly interesting...
Right?!Huh. Chapstick. Who knew.
So in the two tests you've run to date, only XCP and Hornady Oneshot are both in the top 5 products for both tests?
Now I'm interested to see if you throw in testing for lubricity, what's the short list of products that score the highest in all 3 tests? I'm guessing Oneshot will be right up there, and if you add the fact it's highly available for US folks, it's gotta be a pretty viable option.
Related item, I've noticed the last couple years in multiple firearm forums, it's been gaining momentum and more people switching to Oneshot. I'm seeing a lot of people (and myself) starting to use the Oneshot as their main general purpose "CLP-like" product. For general CLP tasks on most firearms, and especially for things like hosing down AR BCG's that you need to quickly field clean without disassembly, or spraying into a trigger group that you want to clean/lube/protect without removal. And then supplement the Oneshot with specialized products as needed, such as a bore cleaner product and grease for slides/rails. Just recently switched from using WD40 as my all-purpose knife CLP product to Oneshot, and been pretty satisfied with it. It appears to me the solvent in WD40 (which includes kerosene, among other compounds) is still pretty effective as a cleaner. WD40 works great there's nothing wrong with it at all. But when it comes to multipurpose clean/lube/protect in one product, Oneshot is pretty hard to beat if you want stronger corrosion protection and lube properties, which in fact *is* what I want for folding knives.
Wow! What type of Beeswax Chapstick are you using, just the commonly available Burt's Bees stuff?
Yep just the burts beeswax chapstick!
