This is a great thread Daniel and I appreciate the time you take to help us out.
I found a carbidizer in my Old Man's tool box, didn't know what it was till about 6 months ago, (he was a fleet mechanic for Shell Oil and used it for work to resurface contacts and points).
What else is it good for? Can you use it to add material to a liner lock? What other things can you use it for?
Nice score!
Yes you can carbidize the lock bar, it will not add very much material but will make a big difference in the action and wear.
The carbide welds in so there is also carbide in the material you are adding it to, it is more than a surface layer from what I understand.
Try it on drill bits, anything that holds an edge will last longer. Steel and carbide works great too, I really need to make more carbidized steel knives.
I hear they work wonders on mower blades. I mostly use mine on blades and lock bars but this does get me thinking, I need to use it for more.
Hey Daniel A while back I posted a pic of the first hamon I attempted.I have been unable to get what I call a hamon. I can see the temper line when I etch the blade in vinegar. Then I try fresh lemon juice to try to bring out the ashy white line but noooooo go. The blade is 1084 and I used furnace clay on the spine to get the temper line. I quenched it canola. You got any tips? This is what it looked like after rough sanding the scale off.
I think Xander called it with the 1084 but I have seen a hamon on 1084 before so you may have a chance.
That is decarb you are seeing, try a used ceramic belt to get the decarb off.
After that finish up to 400 or so then do a quick dip in vinegar, ferric chloride or wipe with a lemon wedge to see if you have any activity. I find the lemon juice will sometimes bring out subtle activity like quench lines.
If you see any activity or lines go ahead and start hand sanding, I'd bring it to a higher grit like 800-1200 for more activity.
Try W2 for hamon, 1095 or Aldo's 1075 is also a good one. You need a low manganese content in the steel to get a good hamon as the manganese controls hardening depth along with other factors. ...that's why I say Aldo's 1075 as sometimes 1075 can be deep hardening and won't get a hamon.
"Your file is unusable for waterjet work."
Q: Why am I CAD-inept?
Oh no!!!! your CAD looked great to me, I'm going to look it over again.
I did a ton of reading up on it (CAD in general... I'm considering a true 3D program) yesterday and it may be the conversion factor which might not show up until it is in the waterjet. Apparently one type of vector or spline machines well but does not convert as well to the wj.
Keep at it, your designs are top-notch!
