- Aug 21, 2014
it's difficult to determine.At what point would it be porn? This is just busse related science.
you know it when you see it.
My go too at home is a tin of bag balm. Melt down the bag balm, and add about 60 ml of tea tree oil.I would suggest a mixture of crushed raw garlic clove together with Manuka Honey. In my experience this both causes rapid healing of wounds but also reduces infections significantly. It will burn a bit when you put it on, actually both the Manuka honey AND Garlic have this quality on their own. The Manuka honey has antibiotic qualities, especially something with a higher 'K' value. The garlic is also antibiotic for about a day before it begins to lose potency as the compounds break down.
Another quality of honey is that as it is mixed with water (from the wound, which is drawn out through osmosis) it creates a steady formation of hydrogen peroxide. As the wound infects, it will create compounds that will actually breakdown hydrogen peroxide rapidly so regular applications of hydrogen peroxide solutions may not help at this point. I see hydrogen peroxide as most useful before infection sets in but may still help if continued frequently.
Also, if you can purchase one of these lamps and bulbs and use it every day on the wound as much as possible. A treatment should last about 15-20 minutes, and can be repeated three or four times daily for a severe infection. I would almost assume that is going to get infected due to the size of the cut, so the heat will greatly help speed the healing and add needed 'warming' quality to keep away infection.
You can purchase 250 Watt Heat Lamps at many hardware stores, Home Depot sells Philips and Lowe's sells GE brands --- both are good. I recommend ordering a lamp from Amazon or something similar...
If you follow this advice I would expect much more rapid healing than having not followed it but either way, best of luck and I hope things turn out well for you.
Does a shop rag count? Because that is what I did at first..... got some crude oil in there I'm sure. LolRub some dirt in it. God made dirt, and dirt don’t hurt.
You perverts never gave me booze money, so just a plane Jane picture. Lol.We need another update so that I can tell you to go to the hospital again.
You sir, I believe have me beat.I've had my fair share of dumb ideas in my younger drinking days. Like using a neck knife as a spoon to scoop out the last bit of a jello shooter and.... cut the side of my mouth.
It would be healed by now, but chicks dig scars.... or so I hear. Just need to get a better story.shoulda gone to the hospital
Hope you’re doing well.So, fyi, don't use the blade side of your sykco to open a beer..... first busse kin bite.
