BJ987
- Jul 21, 2020
Blade centering is a contentious topic and IMO it comes down to personal preference. If you really mean a few mm as in 3+ mm, that's a lot for a knife with tolerances this tight. Centering is a bit off on mine. I don't mind as long as it doesn't affect functionality.
It's probably not off as much as you think it is. Have you tried tightening the pivot? Might be a bit loose (happened to mine).
I'm so glad I got a hollow ground model. I want to try a flat ground though to compare. My 4max Scout is flat, and it seems like it wouldn't cut all that well because it is pretty thick behind the edge, but it does a respectable job! And is not at all hard to carry. I don't even notice the weight, and I only keep my keyfob in that pocket so I don't have to worry about getting anything out!
Go cut down a tree, the ad10 will do it!
So, maybe not literally a few mm, but you can definitely see here that it is off. The blade looks like it's a mm short of rubbing the liner. The first Kershaw CQC-4KXL I received wasn't centered, and it got worse over only after a few days of playing with it. It got so bad that I could feel/hear the blade scrape the liner when opening (I sent it back and got a replacement). Is that what could happen with my AD-10? If so, I definitely want to send it back. I'm actually already trying to but it looks like it might be the last one that the seller had and I may not be able to get it at that great price again ($120).
