- Jul 13, 2009
Try it.
Be sure to take video.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Is this fast enough?
If he really had skills he wouldn’t have burned most of the blade when he cleaned up that hollow grind on the first grind stone after heat treating, you have to look really carefully but the whole first side is blue and he quickly flips it over and grinds the oxidation offThe man has some serious skills. I would be afraid to be in the same room with him cutting that billet on that huge disc.
Natlek, as much as I would love to see your wheel, I also think it's a bad idea. Imagine for example if your knife tip or something gets stuck between the disc and the work rest and everything explodes in your face. Also I think the discs on the side would maybe be prone to chip as they would have no support on one side. Even if it can be done and grinds super fast and efficient, why would you risk you health for something that can be done in numerous different ways with appropriate tools that you already have? If you have a surplus of time build me a surface grinder and I will send you a stack of ceramic belts that will last you for the next 10 years![]()
Why ? Do you think that it is more safe to do that with that size cut off disc mounted on angle grinder ? Think about that ..... Many Russian knife maker use that .The man has some serious skills. I would be afraid to be in the same room with him cutting that billet on that huge disc.
I wonder what spin in this setup ? Saw or angle grinderSomeone beat you to it.
But it does free up the angle grinder...
I will , do you think that I will filming my suicideTry it.
So you think that I will end up here .................I’d say this is natural selection at its best![]()
Why ? I would like to hear what you think about this ? Just don t write that this is bad idea without explanation why it is bad idea ?
Sorry but the surface finish it will leave will not be acceptable. All the spaces between the discs will essentially leave serrated type finish on the metal.
This idea is so bad it is almost as if you are bored an just are looking for a reason for people to tell you how bad of an idea it is.
There is a standard of quality we strive for here on ShopTalk and this cobbled together cut off disc grinder is not one of them.
I don't believe that spaces between the discs would make problem
great idea for making a serrated blade.... not sure how you will get everything tightened up enough to run trouble free ,but have some fun with the idea..
