timos , the common definition of "precipitate" is in the hardening process of 'precipitation hardening ' where a secondary compound is formed which strengthens the metal . One of the basic strengthening mechanisms .Secondary hardening of tool steels , cryo [ formation of the small eta carbides ], are two often spoke of these days. Importantto understand these things.
Jay, I graduated in 1965 when we were limited to optical microscopes at 1000 power.A couple of years later we have electron beam microscopes at 100,000 !! A HUGE change , rewrite the books , throw out incorrect theories !!! Now we have about 1,000,000 including videos of dislocations interacting with precipitates ! WOW
Please try to use up to date terms. Difficult at times but necessary ! Been there done that ,HA, HA !
Now, about your comment about flex, after making thousands of knives, I will clearly state that if you take two nearly identical (because absolutely identical is not possible) blades, and harden and temper one to 55HRC, and another to 60HRC, you'll see that the softer one flexes more than the harder one. So I don't know what you mean.
Jay, I think it is a semantics or terminology issue, here. The elastic modulus for any given steel, regardless of heat treat, remains the same. Hardness dictates how the steel will perform once the elastic limit has been reached. As quenched, full hard steel will fracture and catastrophically fail... Tempered martensite will resist deformation but eventually break... While fully annealled/unhardened steel will readily deform past the elastic limit without much additional force. The scientific fact remains that they all have the same elastic limit. The only variable is the material's cross-section, as I understand it.
Most of us see it as increased "flexibility" when in reality it is bridled(tempered) "strength".
Hi Jay,happy new year to you and yours.I believe I read in your article that you sometimes do a cryo quench in between tempers.I read a while back on the hyper free blades website explaining benefits to basically all stainless steels. By the way I only do what you describe as a shallow cryo (dry ice).Curious if you have any thoughts on this?Any extra conversion? Thanks,Lu
